Solved No Voice Component on Remote Extension, External Calls Only
Discussion in '3CX Phone System - General' started by Wendelspanswick, Jan 18, 2017.
  1. Wendelspanswick
    Jan 11, 2016
    57
    We have a site running V15 sp4 which uses a Patton gateway to connect to the ISDN2 lines, the phones all have a 192.168.xx.xx address and this all works fine.
    We have setup a remote extension on another site that has its own LAN, this phone has a 10.174.xx.xx address, IT have created a tunnel to allow it to see the 3CX and we have registered the phone onto the 3CX.
    Internal calls between the remote extension and the extensions on the 3CX site work correctly but when we try to make an external call from the remote extension although the call connects correctly there is no speech component in either direction on the call.
    We can't understand what could be causing this as if it was a firewall issue surely there would be no speech on the internal calls either, there is no firewall between the 3CX and the Patton, and comparing the Activities Log message blocks from the local phones to the ones from the remote extension they look identical.
  2. MRM
    MRM
    Dec 21, 2016
    53
    Hi Wendel,
    Kindly run the firewall checker and let me know if it passes the test. Also in order to investigate further your issue we shall need a wireshark capture.
    Download Wireshark from http://www.wireshark.org and install on the server.
    Then start a capture ensuring that all the network adapters involved are selected.
    Regards,
  3. Wendelspanswick
    Jan 11, 2016
    57
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,401
    280
    When you say created a tunnel, you mean a VPN? Is the extension provisioned as a local extension?
    Navigate to extension option and enable PBX delivers audio and see if that resolves your issue
  5. Wendelspanswick
    Jan 11, 2016
    57
    Yiannis your a star!!!
    Works perfectly, thank you.
  6. YiannisH_3CX
    May 10, 2016
    4,401
    280
    Glad it worked :)
