No voice external extension
Discussion in '3CX Phone System - General' started by surfie, Aug 5, 2007.
  1. surfie
    May 26, 2007
    31
    Hello
    After solving my problem with the nokia e90 regarding logging in from outside there left one problem.
    The E90 is registered as an external extension with parameters extension is external and Media Server and Reinvite Option.
    All ports are forwarded as documentated in the manual and the posts.
    When calling from the E90 or receiving a call, I can't hear the voice on the other side. Someone any idea?
    In the log the E90 is logged as ext. extension 666 and calls the number 00436621503.
    Here the Log:
    15:24:17.060|SipStack.cxx(278)|Debug8|Resip|>>:SEND: SipResp: 489 tid=-9ce5ef9c cseq=SUBSCRIBE / 1002 from(tu)
    15:24:17.060|c:\svn\src\pbxserver\ServerSubscr.h(222)|Trace5|MessageSubscription|MessageSubscribeHandler::eek:nTerminated:eek:nTerminated(hSub=373)
    15:24:17.060|ServerSubscription.cxx(37)|Debug8|Resip|>>:ServerSubscription::~ServerSubscription
    15:24:17.060|Dialog.cxx(219)|Debug8|Resip|>>:Dialog::~Dialog()
    15:24:17.060|KeepAliveManager.cxx(49)|Debug8|Resip|>>:Association removed for [ V4 192.168.90.50:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    15:24:17.060|KeepAliveManager.cxx(53)|Debug8|Resip|>>:Keepalive 83 removed
    15:24:17.060|KeepAliveManager.cxx(54)|Debug8|Resip|>>:No more association for [ V4 192.168.90.50:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    15:24:17.060|DialogUsageManager.cxx(1938)|Debug8|Resip|>>:Got merged request removal request
    15:24:17.060|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer:
    15:24:17.060|DialogSet.cxx(122)|Debug8|Resip|>>: ********** DialogSet::~DialogSet: 40f2d594-638b233b@192.168.90.50-9c0abb76*************
    15:24:17.070|TcpBaseTransport.cxx(141)|Debug8|Resip|>>:TcpBaseTransport::processSomeReads() CONN: 0176A878 732 [ V4 91.8.84.249:57673 TCP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 TCP target domain=unspecified connectionId=0 ] connectionId=4 ]
    15:24:17.070|ConnectionBase.cxx(79)|Debug8|Resip|>>:In State: PartialBody
    15:24:17.070|ConnectionBase.cxx(288)|Debug8|Resip|>>:##ConnectionBase: CONN_BASE: 0176A878 [ V4 91.8.84.249:57673 TCP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 TCP target domain=unspecified connectionId=0 ] connectionId=4 ] received: INVITE sip:00436621503@pneusoft.dyndns.org;user=phone SIP/2.0
    Via: SIP/2.0/TCP 192.168.90.78:5060;branch=z9hG4bKntc9vq2vo5hc6c40ghbcel1;rport
    Max-Forwards: 70
    Route: <sip:pneusoft.dyndns.org;lr>
    Contact: <sip:666@192.168.90.78>
    To: <sip:00436621503@pneusoft.dyndns.org;user=phone>
    From: <sip:666@192.168.90.115>;tag=frv9vq43b9hc7a5ughbf
    Call-ID: CNivWeKToIegcEhmWnI5rjJ3By6Avs
    CSeq: 1246 INVITE
    Expires: 120
    Accept: application/sdp
    Allow: INVITE, ACK, BYE, CANCEL, REFER, NOTIFY, OPTIONS, PRACK
    Content-Type: application/sdp
    Proxy-Authorization: Digest realm="3CXPhoneSystem",nonce="12830793078:252a8b8559484363a8e2dbdbba24ff96",algorithm=MD5,username="666",uri="sip:00436621503@pneusoft.dyndns.org;user=phone",response="a72bce4a61464f327988c69b20ac7ddc"
    Supported: 100rel, sec-agree
    User-Agent: Nokia RA-6 V 07.24.0.3
    Privacy: none
    P-Preferred-Identity: sip:666@192.168.90.115
    Content-Length: 447
    v=0
    o=Nokia-SIPUA 63354583424107125 63354583424107125 IN IP4 192.168.90.78
    s=-
    c=IN IP4 192.168.90.78
    t=0 0
    m=audio 49152 RTP/AVP 96 0 8 97 18 98 13
    a=sendrecv
    a=ptime:20
    a=maxptime:200
    a=fmtp:96 mode-change-neighbor=1
    a=fmtp:18 annexb=no
    a=fmtp:98 0-15
    a=rtpmap:96 AMR/8000/1
    a=rtpmap:0 PCMU/8000/1
    a=rtpmap:8 PCMA/8000/1
    a=rtpmap:97 iLBC/8000/1
    a=rtpmap:18 G729/8000/1
    a=rtpmap:98 telephone-event/8000/1
    a=rtpmap:13 CN/8000/1
    15:24:17.070|Transport.cxx(259)|Debug8|Resip|>>:incoming from: [ V4 91.8.84.249:57673 TCP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 TCP target domain=unspecified connectionId=0 ] connectionId=4 ]
    15:24:17.070|TcpBaseTransport.cxx(145)|Debug8|Resip|>>:TcpBaseTransport::processSomeReads() read=447
    15:24:17.070|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer J tid=-9ce5ef9c ms=32000
    15:24:17.070|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 192.168.90.50:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] -> [ V4 192.168.90.115:0 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] sent-by=192.168.90.50 sent-port=5060
    15:24:17.070|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 192.168.90.50:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 192.168.90.115:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]SIP/2.0 489 Event Package Not Supported
    Via: SIP/2.0/UDP 192.168.90.50:5060;branch=z9hG4bK-9ce5ef9c
    To: <sip:192.168.90.115>;tag=9c0abb76
    From: "Daniel Smerda"<sip:100@192.168.90.115>;tag=722fd164b536f465
    Call-ID: 40f2d594-638b233b@192.168.90.50
    CSeq: 1002 SUBSCRIBE
    User-Agent: 3CXPhoneSystem
    Content-Length: 0
    15:24:17.070|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 192.168.90.50:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    15:24:17.070|TransactionUser.cxx(66)|Debug8|Resip|>>:Checking if SipReq: INVITE 00436621503@pneusoft.dyndns.org tid=ntc9vq2vo5hc6c40ghbcel1 cseq=INVITE contact=666@192.168.90.78 / 1246 from(wire) is for me
    15:24:17.070|TransactionUser.cxx(71)|Debug8|Resip|>>:Checking rule...
    15:24:17.070|MessageFilterRule.cxx(42)|Debug8|Resip|>>:Matching rule for INVITE sip:00436621503@pneusoft.dyndns.org;user=phone SIP/2.0
    Via: SIP/2.0/TCP 192.168.90.78:5060;branch=z9hG4bKntc9vq2vo5hc6c40ghbcel1;rport=57673;received=91.8.84.249
    Max-Forwards: 70
    CSeq: 1246 INVITE
    Expires: 120
    Privacy: none
    Content-Length: 447
    v=0
    s=-
    t=0 0
    a=sendrecv
    a=ptime:20
    a=maxptime:200
    a=fmtp:18 annexb=no
    a=fmtp:98 0-15
    15:24:17.070|TransactionUser.cxx(74)|Debug8|Resip|>>:Match!
    15:24:17.070|Helper.cxx(302)|Debug8|Resip|>>:Helper::makeResponse(SipReq: INVITE 00436621503@pneusoft.dyndns.org tid=ntc9vq2vo5hc6c40ghbcel1 cseq=INVITE contact=666@192.168.90.78 / 1246 from(wire) code=100 reason=
    15:24:17.070|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer Trying tid=ntc9vq2vo5hc6c40ghbcel1 ms=80
    15:24:17.070|TransactionState.cxx(1721)|Debug8|Resip|>>:Send to TU: TU: DialogUsageManager size=0 INVITE sip:00436621503@pneusoft.dyndns.org;user=phone SIP/2.0
    Max-Forwards: 70
    CSeq: 1246 INVITE
    Expires: 120
    Privacy: none
    Content-Length: 447
    v=0
    s=-
    t=0 0
    a=sendrecv
    a=ptime:20
    a=maxptime:200
    a=fmtp:18 annexb=no
    a=fmtp:98 0-15
    15:24:17.080|.\Authorization.cpp(165)|Message5|Authorization|AuthMgr::handle:handle:
    Max-Forwards: 70
    CSeq: 1246 INVITE
    Expires: 120
    Privacy: none
    Content-Length: 447
    v=0
    s=-
    t=0 0
    a=sendrecv
    a=ptime:20
    a=maxptime:200
    a=fmtp:18 annexb=no
    a=fmtp:98 0-15
    15:24:17.080|DialogSetId.cxx(31)|Debug8|Resip|>>:********** Generated Local Tag ***********
    15:24:17.080|DialogId.cxx(50)|Debug8|Resip|>>:DialogId::DialogId: CNivWeKToIegcEhmWnI5rjJ3By6Avs-c10ac341-frv9vq43b9hc7a5ughbf
    15:24:17.080|.\Authorization.cpp(216)|Debug2|Authorization|AuthMgr::handle:Invite session is not found
    15:24:17.090|ServerAuthManager.cxx(307)|Trace5|Resip|>>:Requesting credential for 666 @ 3CXPhoneSystem
    15:24:17.090|Helper.cxx(801)|Debug8|Resip|>>:Authenticating: realm=3CXPhoneSystem expires=0
    15:24:17.090|Helper.cxx(865)|Trace5|Resip|>>: username=666 password=audia8 realm=3CXPhoneSystem method=INVITE uri=sip:00436621503@pneusoft.dyndns.org;user=phone nonce=12830793078:252a8b8559484363a8e2dbdbba24ff96
    15:24:17.090|ServerAuthManager.cxx(47)|Trace5|Resip|>>:ServerAuth requested credentials SipReq: INVITE 00436621503@pneusoft.dyndns.org tid=ntc9vq2vo5hc6c40ghbcel1 cseq=INVITE contact=666@192.168.90.78 / 1246 from(wire)
    15:24:17.090|ServerAuthManager.cxx(125)|Trace5|Resip|>>:Checking for auth result in realm=3CXPhoneSystem A1=
    15:24:17.090|ServerAuthManager.cxx(210)|Trace5|Resip|>>:Authorized request for 3CXPhoneSystem
    15:24:17.090|.\Authorization.cpp(294)|Trace5|Authorization|AuthMgr::eek:nAuthSuccess:Caller <sip:666@192.168.90.115>;tag=frv9vq43b9hc7a5ughbf has been authenticated successfully
    15:24:17.090|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipReq: INVITE 00436621503@pneusoft.dyndns.org tid=ntc9vq2vo5hc6c40ghbcel1 cseq=INVITE contact=666@192.168.90.78 / 1246 from(wire)
    15:24:17.090|DialogUsageManager.cxx(1456)|Debug8|Resip|>>:DialogUsageManager::processRequest: SipReq: INVITE 00436621503@pneusoft.dyndns.org tid=ntc9vq2vo5hc6c40ghbcel1 cseq=INVITE contact=666@192.168.90.78 / 1246 from(wire)
    15:24:17.090|DialogSetId.cxx(31)|Debug8|Resip|>>:********** Generated Local Tag ***********
    15:24:17.090|DialogSet.cxx(84)|Debug8|Resip|>>: ************* Created DialogSet(UAS) -- CNivWeKToIegcEhmWnI5rjJ3By6Avs-3f15cf3f*************
    15:24:17.090|.\CallMgr.cpp(349)|Trace5|CallControl|ADSFactory::createAppDialogSet:Creating ADS for INVITE
    15:24:17.090|.\CallConf.cpp(506)|Trace5|CallControl|CallConf::CallConf:Call created: 3
    15:24:17.090|.\CallConf.cpp(445)|Trace5|CallControl|CallConf::addCallLeg:Added leg# 1 to call 3
    15:24:17.090|.\Call.cpp(1372)|Trace5|CallControl|CallLegImpl::CallLegImpl:Leg @L:1@C:3 is created
    15:24:17.090|DialogId.cxx(50)|Debug8|Resip|>>:DialogId::DialogId: CNivWeKToIegcEhmWnI5rjJ3By6Avs-912f9671-frv9vq43b9hc7a5ughbf
    15:24:17.090|DialogSet.cxx(717)|Debug8|Resip|>>:Creating a new Dialog from msg: INVITE sip:00436621503@pneusoft.dyndns.org;user=phone SIP/2.0
    Max-Forwards: 70
    CSeq: 1246 INVITE
    Expires: 120
    Privacy: none
    Content-Length: 447
    v=0
    s=-
    t=0 0
    a=sendrecv
    a=ptime:20
    a=maxptime:200
    a=fmtp:18 annexb=no
    a=fmtp:98 0-15
    15:24:17.090|Dialog.cxx(87)|Debug8|Resip|>>:UAS dialog ID creation, DS: CNivWeKToIegcEhmWnI5rjJ3By6Avs-3f15cf3f
    15:24:17.090|DialogId.cxx(63)|Debug8|Resip|>>:DialogId::DialogId: CNivWeKToIegcEhmWnI5rjJ3By6Avs-3f15cf3f-frv9vq43b9hc7a5ughbf
    15:24:17.090|Dialog.cxx(129)|Debug8|Resip|>>:************** Created Dialog as UAS **************
    15:24:17.090|Dialog.cxx(130)|Debug8|Resip|>>:mRemoteNameAddr: <sip:666@192.168.90.115>;tag=frv9vq43b9hc7a5ughbf
    15:24:17.090|Dialog.cxx(131)|Debug8|Resip|>>:mLocalNameAddr: <sip:00436621503@pneusoft.dyndns.org;user=phone>;tag=3f15cf3f
    15:24:17.090|Dialog.cxx(132)|Debug8|Resip|>>:mLocalContact: <sip:00436621503@pneusoft.dyndns.org;user=phone>
    15:24:17.090|Dialog.cxx(133)|Debug8|Resip|>>:mRemoteTarget: <sip:666@192.168.90.78>
    15:24:17.090|Dialog.cxx(214)|Debug8|Resip|>>:Dialog::Dialog CNivWeKToIegcEhmWnI5rjJ3By6Avs-3f15cf3f-frv9vq43b9hc7a5ughbf
    15:24:17.090|DialogSet.cxx(755)|Debug8|Resip|>>:### Calling CreateAppDialog ### INVITE sip:00436621503@pneusoft.dyndns.org;user=phone SIP/2.0
    Max-Forwards: 70
    CSeq: 1246 INVITE
    Expires: 120
    Privacy: none
    Content-Length: 447
    v=0
    s=-
    t=0 0
    a=sendrecv
    a=ptime:20
    a=maxptime:200
    a=fmtp:18 annexb=no
    a=fmtp:98 0-15
    15:24:17.090|Dialog.cxx(300)|Debug8|Resip|>>:Dialog::dispatch: SipReq: INVITE 00436621503@pneusoft.dyndns.org tid=ntc9vq2vo5hc6c40ghbcel1 cseq=INVITE contact=666@192.168.90.78 / 1246 from(wire)
    15:24:17.090|KeepAliveManager.cxx(19)|Debug8|Resip|>>:First keep alive for: [ V4 91.8.84.249:57673 TCP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 TCP target domain=unspecified connectionId=0 ] connectionId=4 ]
    15:24:17.090|KeepAliveManager.cxx(20)|Debug8|Resip|>>:Keepalive interval 180 seconds
    15:24:17.090|KeepAliveManager.cxx(21)|Debug8|Resip|>>:Keepalive id 84
    15:24:17.090|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: [ V4 91.8.84.249:57673 TCP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 TCP target domain=unspecified connectionId=0 ] connectionId=4 ](84)
    15:24:17.090|Dialog.cxx(332)|Debug8|Resip|>>:Dialog::dispatch -- Created new server invite sessionSipReq: INVITE 00436621503@pneusoft.dyndns.org tid=ntc9vq2vo5hc6c40ghbcel1 cseq=INVITE contact=666@192.168.90.78 / 1246 from(wire)
    15:24:17.090|InviteSession.cxx(73)|Debug8|Resip|>>:^^^ InviteSession::InviteSession 017A0FB8
    15:24:17.090|SipMessage.cxx(964)|Debug8|Resip|>>:SipMessage::getContents: application/sdp
    15:24:17.090|Helper.cxx(1902)|Debug8|Resip|>>:Got sdp
    15:24:17.090|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAS_Start -> UAS_Offer
    15:24:17.090|.\ISHandler.cpp(21)|Trace5|CallControl|ISHandler::eek:nNewSession:Incoming: sis=376;oat=Offer;rl=INVITE sip:00436621503@pneusoft.dyndns.org;user=phone SIP/2.0
    15:24:17.110|.\Endpoint.cpp(35)|Trace5|Endpoint|Endpoint::findSource:Settings for caller is found: CfgExt:666
    15:24:17.110|UserProfile.cxx(135)|Debug8|Resip|>>:Adding credential: realm=3CXPhoneSystem user=internal
    15:24:17.110|.\Call.cpp(125)|Trace5|CallControl|CallLegImpl::eek:nIncoming:Endpoint is built: Ext.666
    15:24:17.200|.\Call.cpp(693)|Trace5|CallControl|CallLegImpl::initMSEndpoint:Created external MS endpoint for Ext.666: addr=91.8.84.249:9002
    15:24:17.200|ServerInviteSession.cxx(91)|Trace5|Resip|>>:UAS_Offer: provisional(100)
    15:24:17.200|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAS_Offer -> UAS_EarlyOffer
    15:24:17.200|Helper.cxx(302)|Debug8|Resip|>>:Helper::makeResponse(SipReq: INVITE 00436621503@pneusoft.dyndns.org tid=ntc9vq2vo5hc6c40ghbcel1 cseq=INVITE contact=666@192.168.90.78 / 1246 from(wire) code=100 reason=
    15:24:17.200|Dialog.cxx(970)|Debug8|Resip|>>:Dialog::makeResponse: SIP/2.0 100 Trying
    To: <sip:00436621503@pneusoft.dyndns.org;user=phone>;tag=3f15cf3f
    CSeq: 1246 INVITE
    Content-Length: 0
    15:24:17.200|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: DumTimeout::Retransmit1xx INVITE: 376 UAS_EarlyOffer ADDR=<sip:00436621503@pneusoft.dyndns.org;user=phone>;tag=3f15cf3f PEER=<sip:666@192.168.90.115>;tag=frv9vq43b9hc7a5ughbf: duration=60 seq=1246
    15:24:17.200|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend:InviteSession(376) sends SIP/2.0 100 Trying
    15:24:17.200|.\ISHandler.cpp(141)|Message5|CallControl|ISHandler::eek:nReadyToSend:IS(376) sends:
    SIP/2.0 100 Trying
    CSeq: 1246 INVITE
    Content-Length: 0
    15:24:17.200|DialogUsageManager.cxx(800)|Debug8|Resip|>>:SEND: SIP/2.0 100 Trying
    CSeq: 1246 INVITE
    Content-Length: 0
    15:24:17.200|SipStack.cxx(278)|Debug8|Resip|>>:SEND: SipResp: 100 tid=ntc9vq2vo5hc6c40ghbcel1 cseq=INVITE / 1246 from(tu)
    15:24:17.210|.\CallConf.cpp(120)|Log2|CallControl|CallConf::eek:nIncoming:[CM103002] Call(3): Incoming call from 666 (Ext.666) to sip:00436621503@pneusoft.dyndns.org
    15:24:17.210|.\CallStrategies.cpp(439)|Trace5|CallManager|StratInOut::initialize:Initialize InOut call strategy
    15:24:17.250|.\DBAccessor.cpp(1222)|Trace5|DataBase|DBPostgressAccessor::findDestinationsEx:Will use outbound rule rule ID=1
    15:24:17.280|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 91.8.84.249:57673 TCP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 TCP target domain=unspecified connectionId=0 ] connectionId=4 ] -> [ V4 192.168.90.115:0 TCP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 TCP target domain=unspecified connectionId=0 ] connectionId=4 ] sent-by=192.168.90.78 sent-port=5060
    15:24:17.280|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 91.8.84.249:57673 TCP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 TCP target domain=unspecified connectionId=0 ] connectionId=4 ] tlsDomain= via [ V4 192.168.90.115:5060 TCP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 TCP target domain=unspecified connectionId=0 ] connectionId=4 ]SIP/2.0 100 Trying
    CSeq: 1246 INVITE
    Content-Length: 0
    15:24:17.280|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 91.8.84.249:57673 TCP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 TCP target domain=unspecified connectionId=0 ] connectionId=4 ]
    15:24:17.300|.\CallTarget.cpp(374)|Trace5|CallManager|CT_Lines::selectNextTarget:Select new line for outbound call
    15:24:17.380|TcpBaseTransport.cxx(170)|Debug8|Resip|>>:processing write for [ V4 91.8.84.249:57673 TCP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 TCP target domain=unspecified connectionId=0 ] connectionId=4 ]
    15:24:17.380|ConnectionManager.cxx(52)|Debug8|Resip|>>:Found connection id 4
    15:24:17.380|TcpConnection.cxx(81)|Debug8|Resip|>>:Writing SIP/2.0 100 Trying
    CSeq: 1246 INVITE
    Content-Length: 0
    15:24:17.380|.\Call.cpp(693)|Trace5|CallControl|CallLegImpl::initMSEndpoint:Created external MS endpoint for Ln:10001@0720101111: addr=91.8.84.249:9004
    15:24:17.380|.\CallConf.cpp(445)|Trace5|CallControl|CallConf::addCallLeg:Added leg# 2 to call 3
    15:24:17.380|UserProfile.cxx(135)|Debug8|Resip|>>:Adding credential: realm=3CXPhoneSystem user=167529
    15:24:17.380|UserProfile.cxx(135)|Debug8|Resip|>>:Adding credential: realm=node1.voicenode.at user=167529
    15:24:17.380|.\Call.cpp(1372)|Trace5|CallControl|CallLegImpl::CallLegImpl:Leg 10001@L:2@C:3 is created
    15:24:17.380|.\CallTarget.cpp(389)|Trace5|CallManager|CT_Lines::selectNextTarget:Line Ln:10001@0720101111 is found for outbound call
    15:24:17.390|.\CallConf.cpp(132)|Trace5|CallControl|CallConf::eek:nIncoming:MediaServer could be used for this call
    15:24:17.390|.\ISHandler.cpp(157)|Trace5|CallControl|ISHandler::eek:nOffer:Offered: is=376; rl=INVITE sip:00436621503@pneusoft.dyndns.org;user=phone SIP/2.0
    15:24:17.390|.\Call.cpp(195)|Message5|CallControl|CallLegImpl::eek:nOfferProvided:Leg.onOffer 666@L:1@C:3 got:
    Max-Forwards: 70
    CSeq: 1246 INVITE
    Expires: 120
    Privacy: none
    Content-Length: 447
    v=0
    s=-
    t=0 0
    a=sendrecv
    a=ptime:20
    a=maxptime:200
    a=fmtp:18 annexb=no
    a=fmtp:98 0-15
    15:24:17.400|.\CallStrategies.cpp(643)|Trace5|CallManager|StratInOut::eek:nOffer:InOut: got offer from 666@L:1@C:3
    15:24:17.400|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: Calling; DN 666
    15:24:17.400|.\CallTarget.cpp(443)|Trace5|CallManager|CT_Lines::Invite:Rule (0043): Placing call to line 10001@L:2@C:3 to reach 00436621503
    15:24:17.400|BaseCreator.cxx(127)|Debug8|Resip|>>:BaseCreator::makeInitialRequest: 0179BDC8
    15:24:17.400|DialogSet.cxx(52)|Debug8|Resip|>>: ************* Created DialogSet(UAC) -- MTczOTM5YjZkYjBjMjBmODZhNTMwZmE1ZDNmODhiYjA.-ee16d001*************
    15:24:17.400|DialogUsageManager.cxx(800)|Debug8|Resip|>>:SEND: INVITE sip:00436621503@node1.voicenode.at:5060 SIP/2.0
    Via: SIP/2.0/ ;branch=z9hG4bK-d87543-0314d0218a1bd626-1--d87543-;rport
    Max-Forwards: 70
    Contact: <sip:167529@91.8.84.249:5060>
    To: "7201011111"<sip:10001@node1.voicenode.at:5060>
    From: "7201011111"<sip:167529@node1.voicenode.at>;tag=ee16d001
    Call-ID: MTczOTM5YjZkYjBjMjBmODZhNTMwZmE1ZDNmODhiYjA.
    CSeq: 1 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
    Content-Length: 247
    v=0
    o=3cxPS 12830793857300 12830793857301 IN IP4 192.168.90.115
    s=3cxPS Audio call
    c=IN IP4 91.8.84.249
    t=0 0
    m=audio 9004 RTP/AVP 0 8 3 101
    a=rtpmap:3 GSM/8000
    a=rtpmap:101 telephone-event/8000
    15:24:17.400|DialogId.cxx(50)|Debug8|Resip|>>:DialogId::DialogId: MTczOTM5YjZkYjBjMjBmODZhNTMwZmE1ZDNmODhiYjA.-ee16d001-
    15:24:17.400|DialogUsageManager.cxx(912)|Debug8|Resip|>>:Using outbound proxy: sip:167529@node1.voicenode.at:5060;lr -> SipReq: INVITE 00436621503@node1.voicenode.at:5060 tid=0314d0218a1bd626 cseq=INVITE contact=167529@91.8.84.249:5060 / 1 from(tu)
    15:24:17.400|.\Call.cpp(770)|Message5|CallControl|CallLegImpl::Invite:Sent:
    Max-Forwards: 70
    CSeq: 1 INVITE
    Content-Length: 247
    v=0
    s=3cxPS Audio call
    t=0 0
    a=rtpmap:3 GSM/8000
    15:24:17.481|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer B tid=0314d0218a1bd626 ms=32000
    15:24:17.481|DnsResult.cxx(186)|Debug8|Resip|>>:DnsResult::lookup sip:167529@node1.voicenode.at:5060;lr
    15:24:17.481|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer A tid=0314d0218a1bd626 ms=500
    15:24:17.481|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 213.164.25.150:5060 UDP target domain=node1.voicenode.at connectionId=0 ] -> [ V4 192.168.90.115:0 UDP target domain=node1.voicenode.at connectionId=0 ] sent-by= sent-port=0
    15:24:17.481|TransportSelector.cxx(971)|Debug8|Resip|>>:findTransportBySource([ V4 192.168.90.115:0 UDP target domain=node1.voicenode.at connectionId=0 ])
    15:24:17.481|TransportSelector.cxx(1083)|Debug8|Resip|>>:findTransport (any port, any interface) => Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ]
    15:24:17.481|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 213.164.25.150:5060 UDP target domain=node1.voicenode.at received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 192.168.90.115:5060 UDP target domain=node1.voicenode.at connectionId=0 ]INVITE sip:00436621503@node1.voicenode.at:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.90.115:5060;branch=z9hG4bK-d87543-0314d0218a1bd626-1--d87543-;rport
    Max-Forwards: 70
    CSeq: 1 INVITE
    Content-Length: 247
    v=0
    s=3cxPS Audio call
    t=0 0
    a=rtpmap:3 GSM/8000
    15:24:17.481|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 213.164.25.150:5060 UDP target domain=node1.voicenode.at received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    15:24:17.581|Transport.cxx(259)|Debug8|Resip|>>:incoming from: [ V4 213.164.25.150:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    15:24:17.581|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer D tid=0314d0218a1bd626 ms=32000
    15:24:17.581|TransportSelector.cxx(388)|Debug8|Resip|>>:hint provided by app: SIP/2.0/UDP 192.168.90.115:5060;branch=z9hG4bK-d87543-0314d0218a1bd626-1--d87543-;rport
    15:24:17.581|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 213.164.25.150:5060 UDP target domain=node1.voicenode.at received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 192.168.90.115:5060 UDP target domain=unspecified connectionId=0 ]ACK sip:00436621503@node1.voicenode.at:5060 SIP/2.0
    To: "7201011111"<sip:10001@node1.voicenode.at:5060>;tag=as14552a43
    CSeq: 1 ACK
    Content-Length: 0
    15:24:17.581|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 213.164.25.150:5060 UDP target domain=node1.voicenode.at received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    15:24:17.581|DnsResult.cxx(177)|Debug8|Resip|>>:Whitelisting node1.voicenode.at(1): 213.164.25.150
    15:24:17.581|dns\RRVip.cxx(129)|Debug8|Resip|>>:updating an existing vip: 213.164.25.150 with 213.164.25.150
    15:24:17.581|TransactionState.cxx(1721)|Debug8|Resip|>>:Send to TU: TU: DialogUsageManager size=0 SIP/2.0 407 Proxy Authentication Required
    Via: SIP/2.0/UDP 192.168.90.115:5060;branch=z9hG4bK-d87543-0314d0218a1bd626-1--d87543-;received=91.8.84.249;rport=5060
    Proxy-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="4cebbbe8"
    Contact: <sip:00436621503@213.164.25.150>
    CSeq: 1 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
    User-Agent: Voicenode Providersystem v 3.5.1
    Content-Length: 0
    15:24:17.581|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipResp: 407 tid=0314d0218a1bd626 cseq=INVITE contact=00436621503@213.164.25.150 / 1 from(wire)
    15:24:17.581|DialogUsageManager.cxx(1646)|Debug8|Resip|>>:DialogUsageManager::processResponse: SipResp: 407 tid=0314d0218a1bd626 cseq=INVITE contact=00436621503@213.164.25.150 / 1 from(wire)
    15:24:17.581|ClientAuthManager.cxx(219)|Debug8|Resip|>>:ClientAuthManager::RealmState::handleAuth: 01773CF0 Digest algorithm=MD5,realm="asterisk",nonce="4cebbbe8" is proxy: 1
    15:24:17.581|ClientAuthManager.cxx(193)|Debug8|Resip|>>:ClientAuthManager::RealmState::transition from invalid to current
    15:24:17.581|UserProfile.cxx(153)|Debug8|Resip|>>:Didn't find credential for realm: asterisk realm=3CXPhoneSystem user=167529
    15:24:17.581|ClientAuthManager.cxx(58)|Debug8|Resip|>>:produced response to digest challenge for UserProfile: "7201011111"<sip:167529@node1.voicenode.at>[realm=3CXPhoneSystem user=167529, realm=node1.voicenode.at user=167529]
    15:24:17.581|DialogSet.cxx(244)|Debug8|Resip|>>:about to re-send request with digest credentials
    15:24:17.581|ClientAuthManager.cxx(313)|Debug8|Resip|>>: Add auth, 01773CF0 in response to: Digest algorithm=MD5,realm="asterisk",nonce="4cebbbe8"
    15:24:17.581|ClientAuthManager.cxx(321)|Debug8|Resip|>>:ClientAuthManager::RealmState::addAuthentication, proxy: 1 Digest username="167529",realm="asterisk",nonce="4cebbbe8",uri="sip:00436621503@node1.voicenode.at:5060",response="e966caa260bf6db0e2d492e4e63cfe6c",algorithm=MD5
    15:24:17.581|DialogUsageManager.cxx(800)|Debug8|Resip|>>:SEND: INVITE sip:00436621503@node1.voicenode.at:5060 SIP/2.0
    Via: SIP/2.0/ ;branch=z9hG4bK-d87543-e51f97392803c94c-1--d87543-;rport
    Max-Forwards: 70
    CSeq: 2 INVITE
    Proxy-Authorization: Digest username="167529",realm="asterisk",nonce="4cebbbe8",uri="sip:00436621503@node1.voicenode.at:5060",response="e966caa260bf6db0e2d492e4e63cfe6c",algorithm=MD5
    Content-Length: 247
    v=0
    s=3cxPS Audio call
    t=0 0
    a=rtpmap:3 GSM/8000
    15:24:17.581|DialogId.cxx(50)|Debug8|Resip|>>:DialogId::DialogId: MTczOTM5YjZkYjBjMjBmODZhNTMwZmE1ZDNmODhiYjA.-ee16d001-
    15:24:17.581|DialogUsageManager.cxx(912)|Debug8|Resip|>>:Using outbound proxy: sip:167529@node1.voicenode.at:5060;lr -> SipReq: INVITE 00436621503@node1.voicenode.at:5060 tid=e51f97392803c94c cseq=INVITE contact=167529@91.8.84.249:5060 / 2 from(tu)
    15:24:17.681|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer B tid=e51f97392803c94c ms=32000
    15:24:17.681|DnsResult.cxx(186)|Debug8|Resip|>>:DnsResult::lookup sip:167529@node1.voicenode.at:5060;lr
    15:24:17.681|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer A tid=e51f97392803c94c ms=500
    15:24:17.681|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 213.164.25.150:5060 UDP target domain=node1.voicenode.at connectionId=0 ] -> [ V4 192.168.90.115:0 UDP target domain=node1.voicenode.at connectionId=0 ] sent-by= sent-port=0
    15:24:17.681|TransportSelector.cxx(971)|Debug8|Resip|>>:findTransportBySource([ V4 192.168.90.115:0 UDP target domain=node1.voicenode.at connectionId=0 ])
    15:24:17.681|TransportSelector.cxx(1083)|Debug8|Resip|>>:findTransport (any port, any interface) => Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ]
    15:24:17.681|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 213.164.25.150:5060 UDP target domain=node1.voicenode.at received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ] tlsDomain= via [ V4 192.168.90.115:5060 UDP target domain=node1.voicenode.at connectionId=0 ]INVITE sip:00436621503@node1.voicenode.at:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.90.115:5060;branch=z9hG4bK-d87543-e51f97392803c94c-1--d87543-;rport
    Max-Forwards: 70
    CSeq: 2 INVITE
    Content-Length: 247
    v=0
    s=3cxPS Audio call
    t=0 0
    a=rtpmap:3 GSM/8000
    15:24:17.681|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 213.164.25.150:5060 UDP target domain=node1.voicenode.at received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    15:24:17.781|Transport.cxx(259)|Debug8|Resip|>>:incoming from: [ V4 213.164.25.150:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    15:24:17.781|DnsResult.cxx(177)|Debug8|Resip|>>:Whitelisting node1.voicenode.at(1): 213.164.25.150
    15:24:17.781|dns\RRVip.cxx(129)|Debug8|Resip|>>:updating an existing vip: 213.164.25.150 with 213.164.25.150
    15:24:17.781|TransactionState.cxx(1721)|Debug8|Resip|>>:Send to TU: TU: DialogUsageManager size=0 SIP/2.0 100 Trying
    Via: SIP/2.0/UDP 192.168.90.115:5060;branch=z9hG4bK-d87543-e51f97392803c94c-1--d87543-;received=91.8.84.249;rport=5060
    CSeq: 2 INVITE
    Content-Length: 0
    15:24:17.781|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipResp: 100 tid=e51f97392803c94c cseq=INVITE contact=00436621503@213.164.25.150 / 2 from(wire)
    15:24:17.781|DialogUsageManager.cxx(1646)|Debug8|Resip|>>:DialogUsageManager::processResponse: SipResp: 100 tid=e51f97392803c94c cseq=INVITE contact=00436621503@213.164.25.150 / 2 from(wire)
    15:24:17.991|Transport.cxx(259)|Debug8|Resip|>>:incoming from: [ V4 213.164.25.150:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    15:24:17.991|TransactionState.cxx(1721)|Debug8|Resip|>>:Send to TU: TU: DialogUsageManager size=0 SIP/2.0 183 Session Progress
    To: "7201011111"<sip:10001@node1.voicenode.at:5060>;tag=as778c69e8
    CSeq: 2 INVITE
    Content-Length: 265
    v=0
    o=root 1222 1222 IN IP4 213.164.25.150
    s=session
    c=IN IP4 213.164.25.150
    t=0 0
    m=audio 18390 RTP/AVP 8 3 0 101
    a=rtpmap:3 GSM/8000
    a=fmtp:101 0-16
    a=silenceSupp:eek:ff - - - -
    15:24:17.991|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipResp: 183 tid=e51f97392803c94c cseq=INVITE contact=00436621503@213.164.25.150 / 2 from(wire)
    15:24:17.991|DialogUsageManager.cxx(1646)|Debug8|Resip|>>:DialogUsageManager::processResponse: SipResp: 183 tid=e51f97392803c94c cseq=INVITE contact=00436621503@213.164.25.150 / 2 from(wire)
    15:24:17.991|ClientAuthManager.cxx(41)|Debug8|Resip|>>:ClientAuthManager::handle: transitioning MTczOTM5YjZkYjBjMjBmODZhNTMwZmE1ZDNmODhiYjA.-ee16d001to cached
    15:24:17.991|ClientAuthManager.cxx(193)|Debug8|Resip|>>:ClientAuthManager::RealmState::transition from current to cached
    15:24:17.991|DialogId.cxx(50)|Debug8|Resip|>>:DialogId::DialogId: MTczOTM5YjZkYjBjMjBmODZhNTMwZmE1ZDNmODhiYjA.-ee16d001-as778c69e8
    15:24:17.991|DialogSet.cxx(717)|Debug8|Resip|>>:Creating a new Dialog from msg: SIP/2.0 183 Session Progress
    CSeq: 2 INVITE
    Content-Length: 265
    v=0
    s=session
    t=0 0
    a=rtpmap:3 GSM/8000
    a=fmtp:101 0-16
    15:24:17.991|Dialog.cxx(205)|Debug8|Resip|>>:************** Created Dialog as UAC **************
    15:24:17.991|Dialog.cxx(206)|Debug8|Resip|>>:mRemoteNameAddr: "7201011111"<sip:10001@node1.voicenode.at:5060>;tag=as778c69e8
    15:24:17.991|Dialog.cxx(207)|Debug8|Resip|>>:mLocalNameAddr: "7201011111"<sip:167529@node1.voicenode.at>;tag=ee16d001
    15:24:17.991|Dialog.cxx(208)|Debug8|Resip|>>:mLocalContact: <sip:167529@91.8.84.249:5060>
    15:24:17.991|Dialog.cxx(209)|Debug8|Resip|>>:mRemoteTarget: <sip:00436621503@213.164.25.150>
    15:24:17.991|Dialog.cxx(214)|Debug8|Resip|>>:Dialog::Dialog MTczOTM5YjZkYjBjMjBmODZhNTMwZmE1ZDNmODhiYjA.-ee16d001-as778c69e8
    15:24:17.991|DialogSet.cxx(755)|Debug8|Resip|>>:### Calling CreateAppDialog ### SIP/2.0 183 Session Progress
    CSeq: 2 INVITE
    Content-Length: 265
    v=0
    s=session
    t=0 0
    a=rtpmap:3 GSM/8000
    a=fmtp:101 0-16
    15:24:17.991|Dialog.cxx(300)|Debug8|Resip|>>:Dialog::dispatch: SipResp: 183 tid=e51f97392803c94c cseq=INVITE contact=00436621503@213.164.25.150 / 2 from(wire)
    15:24:17.991|KeepAliveManager.cxx(40)|Debug8|Resip|>>:Association added for [ V4 213.164.25.150:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    15:24:17.991|Dialog.cxx(547)|Trace5|Resip|>>:Dialog::dispatch, ignoring stray response: SipResp: 183 tid=e51f97392803c94c cseq=INVITE contact=00436621503@213.164.25.150 / 2 from(wire)
    15:24:17.991|Dialog.cxx(567)|Debug8|Resip|>>:Dialog::dispatch -- Created new client invite sessionSipResp: 183 tid=e51f97392803c94c cseq=INVITE contact=00436621503@213.164.25.150 / 2 from(wire)
    15:24:17.991|InviteSession.cxx(73)|Debug8|Resip|>>:^^^ InviteSession::InviteSession 0176E460
    15:24:17.991|SipMessage.cxx(964)|Debug8|Resip|>>:SipMessage::getContents: application/sdp
    15:24:17.991|Helper.cxx(1902)|Debug8|Resip|>>:Got sdp
    15:24:17.991|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAC_Start -> UAC_Early
    15:24:17.991|.\ISHandler.cpp(31)|Trace5|CallControl|ISHandler::eek:nNewSession:Answered: sis=379;oat=None;rl=SIP/2.0 183 Session Progress
    15:24:17.991|.\CallStrategies.cpp(598)|Trace5|CallManager|StratInOut::eek:nAnswered:Call from Ext.666 is answered on Ln:10001@0720101111
    15:24:17.991|.\CallTarget.cpp(452)|Trace5|CallManager|CT_Lines::answered:Call is accepted on 10001@L:2@C:3
    15:24:17.991|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: Ringing; DN 10001
    15:24:17.991|ClientInviteSession.cxx(315)|Trace5|Resip|>>:UAC_Early: startStaleCallTimer
    15:24:17.991|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: DumTimeout::StaleCall INVITE: 379 UAC_Early ADDR="7201011111"<sip:167529@node1.voicenode.at>;tag=ee16d001 PEER="7201011111"<sip:10001@node1.voicenode.at:5060>;tag=as778c69e8: duration=271 seq=2
    15:24:17.991|.\ISHandler.cpp(57)|Trace5|CallControl|ISHandler::eek:nProvisional:provisional: cis=379;rl=SIP/2.0 183 Session Progress
    15:24:17.991|.\Call.cpp(212)|Message5|CallControl|CallLegImpl::eek:nProvisional:Leg.onProv. 10001@L:2@C:3 got:
    CSeq: 2 INVITE
    Content-Length: 265
    v=0
    s=session
    t=0 0
    a=rtpmap:3 GSM/8000
    a=fmtp:101 0-16
    15:24:17.991|.\CallConf.cpp(178)|Log2|CallControl|CallConf::eek:nProvisional:[CM103003] Call(3): Ln:10001@0720101111 is ringing
    15:24:17.991|.\CallStrategies.cpp(658)|Trace5|CallManager|StratInOut::eek:nProvisional:InOut: got provisional SIP/2.0 183 Session Progress from 10001@L:2@C:3
    15:24:17.991|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: Calling; DN 666
    15:24:17.991|ServerInviteSession.cxx(91)|Trace5|Resip|>>:UAS_EarlyOffer: provisional(180)
    15:24:17.991|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAS_EarlyOffer -> UAS_EarlyOffer
    15:24:17.991|Helper.cxx(302)|Debug8|Resip|>>:Helper::makeResponse(SipReq: INVITE 00436621503@pneusoft.dyndns.org tid=ntc9vq2vo5hc6c40ghbcel1 cseq=INVITE contact=666@192.168.90.78 / 1246 from(wire) code=180 reason=
    15:24:17.991|Dialog.cxx(970)|Debug8|Resip|>>:Dialog::makeResponse: SIP/2.0 180 Ringing
    Contact: "666"<sip:666@91.8.84.249:5060>
    CSeq: 1246 INVITE
    Content-Length: 0
    15:24:17.991|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: DumTimeout::Retransmit1xx INVITE: 376 UAS_EarlyOffer ADDR=<sip:00436621503@pneusoft.dyndns.org;user=phone>;tag=3f15cf3f PEER=<sip:666@192.168.90.115>;tag=frv9vq43b9hc7a5ughbf: duration=60 seq=1246
    15:24:17.991|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend:InviteSession(376) sends SIP/2.0 180 Ringing
    15:24:17.991|.\ISHandler.cpp(141)|Message5|CallControl|ISHandler::eek:nReadyToSend:IS(376) sends:
    SIP/2.0 180 Ringing
    CSeq: 1246 INVITE
    Content-Length: 0
    15:24:17.991|DialogUsageManager.cxx(800)|Debug8|Resip|>>:SEND: SIP/2.0 180 Ringing
    CSeq: 1246 INVITE
    Content-Length: 0
    15:24:17.991|SipStack.cxx(278)|Debug8|Resip|>>:SEND: SipResp: 180 tid=ntc9vq2vo5hc6c40ghbcel1 cseq=INVITE contact=666@91.8.84.249:5060 / 1246 from(tu)
    15:24:17.991|.\ISHandler.cpp(49)|Trace5|CallControl|ISHandler::eek:nEarlyMedia:EarlyMedia: cis=379;rl=SIP/2.0 183 Session Progress
    15:24:18.001|.\Call.cpp(212)|Message5|CallControl|CallLegImpl::eek:nProvisional:Leg.onProv. 10001@L:2@C:3 got:
    CSeq: 2 INVITE
    Content-Length: 265
    v=0
    s=session
    t=0 0
    a=rtpmap:3 GSM/8000
    a=fmtp:101 0-16
    15:24:18.001|.\CallStrategies.cpp(658)|Trace5|CallManager|StratInOut::eek:nProvisional:InOut: got provisional SIP/2.0 183 Session Progress from 10001@L:2@C:3
    15:24:18.001|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: Calling; DN 666
    15:24:18.001|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: Ringing; DN 10001
    15:24:18.001|ServerInviteSession.cxx(91)|Trace5|Resip|>>:UAS_EarlyOffer: provisional(180)
    15:24:18.001|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAS_EarlyOffer -> UAS_EarlyOffer
    15:24:18.001|Helper.cxx(302)|Debug8|Resip|>>:Helper::makeResponse(SipReq: INVITE 00436621503@pneusoft.dyndns.org tid=ntc9vq2vo5hc6c40ghbcel1 cseq=INVITE contact=666@192.168.90.78 / 1246 from(wire) code=180 reason=
    15:24:18.001|Dialog.cxx(970)|Debug8|Resip|>>:Dialog::makeResponse: SIP/2.0 180 Ringing
    CSeq: 1246 INVITE
    Content-Length: 0
    15:24:18.001|TimerQueue.cxx(105)|Debug8|Resip|>>:Adding application timer: DumTimeout::Retransmit1xx INVITE: 376 UAS_EarlyOffer ADDR=<sip:00436621503@pneusoft.dyndns.org;user=phone>;tag=3f15cf3f PEER=<sip:666@192.168.90.115>;tag=frv9vq43b9hc7a5ughbf: duration=60 seq=1246
    15:24:18.001|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend:InviteSession(376) sends SIP/2.0 180 Ringing
    15:24:18.001|.\ISHandler.cpp(141)|Message5|CallControl|ISHandler::eek:nReadyToSend:IS(376) sends:
    SIP/2.0 180 Ringing
    CSeq: 1246 INVITE
    Content-Length: 0
    15:24:18.001|DialogUsageManager.cxx(800)|Debug8|Resip|>>:SEND: SIP/2.0 180 Ringing
    CSeq: 1246 INVITE
    Content-Length: 0
    15:24:18.001|SipStack.cxx(278)|Debug8|Resip|>>:SEND: SipResp: 180 tid=ntc9vq2vo5hc6c40ghbcel1 cseq=INVITE contact=666@91.8.84.249:5060 / 1246 from(tu)
    15:24:18.091|TransportSelector.cxx(525)|Debug8|Resip|>>:Looked up source for destination: [ V4 91.8.84.249:57673 TCP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 TCP target domain=unspecified connectionId=0 ] connectionId=4 ] -> [ V4 192.168.90.115:0 TCP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 TCP target domain=unspecified connectionId=0 ] connectionId=4 ] sent-by=192.168.90.78 sent-port=5060
    15:24:18.091|TransportSelector.cxx(766)|Debug8|Resip|>>:Transmitting to [ V4 91.8.84.249:57673 TCP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 TCP target domain=unspecified connectionId=0 ] connectionId=4 ] tlsDomain= via [ V4 192.168.90.115:5060 TCP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 TCP target domain=unspecified connectionId=0 ] connectionId=4 ]SIP/2.0 180 Ringing
    CSeq: 1246 INVITE
    Content-Length: 0
    15:24:18.091|Transport.cxx(209)|Debug8|Resip|>>:Adding message to tx buffer to: [ V4 91.8.84.249:57673 TCP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 TCP target domain=unspecified connectionId=0 ] connectionId=4 ]
    CSeq: 1246 INVITE
    Content-Length: 0
    15:24:18.192|TcpBaseTransport.cxx(170)|Debug8|Resip|>>:processing write for [ V4 91.8.84.249:57673 TCP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 TCP target domain=unspecified connectionId=0 ] connectionId=4 ]
    15:24:18.192|ConnectionManager.cxx(52)|Debug8|Resip|>>:Found connection id 4
    15:24:18.192|TcpConnection.cxx(81)|Debug8|Resip|>>:Writing SIP/2.0 180 Ringing
    CSeq: 1246 INVITE
    Content-Length: 0
    CSeq: 1246 INVITE
    Content-Length: 0
    15:24:18.612|DialogUsageManager.cxx(1946)|Debug8|Resip|>>:Merged request removed
    15:24:18.983|Transport.cxx(259)|Debug8|Resip|>>:incoming from: [ V4 213.164.25.150:5060 UDP target domain=unspecified received on: Transport: [ V4 0.0.0.0:5060 UDP target domain=unspecified connectionId=0 ] connectionId=0 ]
    15:24:18.993|TransactionState.cxx(1721)|Debug8|Resip|>>:Send to TU: TU: DialogUsageManager size=0 SIP/2.0 200 OK
    CSeq: 2 INVITE
    Content-Length: 265
    v=0
    o=root 1222 1223 IN IP4 213.164.25.150
    s=session
    t=0 0
    a=rtpmap:3 GSM/8000
    a=fmtp:101 0-16
    15:24:18.993|TimerQueue.cxx(85)|Debug8|Resip|>>:Adding timer: Timer StaleClient tid=e51f97392803c94c ms=32000
    15:24:18.993|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipResp: 200 tid=e51f97392803c94c cseq=INVITE contact=00436621503@213.164.25.150 / 2 from(wire)
    15:24:18.993|DialogUsageManager.cxx(1646)|Debug8|Resip|>>:DialogUsageManager::processResponse: SipResp: 200 tid=e51f97392803c94c cseq=INVITE contact=00436621503@213.164.25.150 / 2 from(wire)
    15:24:18.993|ClientAuthManager.cxx(41)|Debug8|Resip|>>:ClientAuthManager::handle: transitioning MTczOTM5YjZkYjBjMjBmODZhNTMwZmE1ZDNmODhiYjA.-ee16d001to cached
    15:24:18.993|ClientAuthManager.cxx(193)|Debug8|Resip|>>:ClientAuthManager::RealmState::transition from cached to cached
    15:24:18.993|DialogId.cxx(50)|Debug8|Resip|>>:DialogId::DialogId: MTczOTM5YjZkYjBjMjBmODZhNTMwZmE1ZDNmODhiYjA.-ee16d001-as778c69e8
    15:24:18.993|DialogSet.cxx(428)|Debug8|Resip|>>:Found matching dialog mClientSubscriptions(0), mServerSubscriptions(0) for
    SIP/2.0 200 OK
    CSeq: 2 INVITE
    Content-Length: 265
    v=0
    s=session
    t=0 0
    a=
