No voice for both line
Discussion in '3CX Phone System - General' started by richard, Jan 19, 2008.
  1. richard
    Jan 18, 2008
    I am using ATCOM IP PHONE model (AT-530P), TP-Link WEb SmartSwitch, I used 3CX IP Phone Systems, everything is ok, the only problem is, I can't hear the voice for both caller and receiver, there is a connection, all IP Phone was registered, there is also a dial tone for every Phone. What should I do, anybody can helpme this problem? Pleaseee........
    second do I need Internet connection whrere I only configured the InterCom (Telephone Inside the Company only)?
    richard
  2. yadac123
    Jan 19, 2008
    24
    is your 3cx box behind a firewall? you need to forward ports 9000 and up.
  3. richard
    Jan 18, 2008
    I got the exact configuration, thanks for your help,
    I have another problem. I could not make outbound call,
    10:27:30.765 Call::Terminate [CM503008]: Call(37): Call is terminated
    10:27:30.734 Call::RouteFailed [CM503014]: Call(37): Attempt to reach "99930920"[sip:99930920@192.168.1.2:5060] failed. Reason: Forbidden
    10:27:30.734 CallLeg::eek:nFailure [CM503003]: Call(37): Call to sip:9930920@192.168.1.55:5060 has failed; Cause: 603 Decline; from IP:192.168.1.55
    10:27:24.531 CallLeg::eek:nFailure [CM503003]: Call(37): Call to sip:9930920@192.168.1.55:5060 has failed; Cause: 603 Decline; from IP:192.168.1.55
    10:27:18.328 CallLeg::eek:nFailure [CM503003]: Call(37): Call to sip:9930920@192.168.1.55:5060 has failed; Cause: 603 Decline; from IP:192.168.1.55
    10:27:12.140 CallLeg::eek:nFailure [CM503003]: Call(37): Call to sip:9930920@192.168.1.55:5060 has failed; Cause: 603 Decline; from IP:192.168.1.55
    10:27:05.968 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(37): Calling: PSTNline:10001@[Dev:sip:10001@192.168.1.55:5060, Dev:sip:10002@192.168.1.55:5060, Dev:sip:10003@192.168.1.55:5060, Dev:sip:10000@192.168.1.55:5060]
    10:27:05.875 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to "99930920"[sip:99930920@192.168.1.2:5060]
    10:27:05.875 Extension::printEndpointInfo [CM505001]: Ext.101: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Voip Phone 1.0] Transport: [sip:192.168.1.2:5060]
    10:27:05.843 CallCtrl::eek:nIncomingCall [CM503001]: Call(37): Incoming call from Ext.101 to "99930920"[sip:99930920@192.168.1.2:5060]
