No Voice on incoming calls
Discussion in '3CX Phone System - General' started by mp3joker, Aug 1, 2008.
  1. mp3joker
    Aug 1, 2008
    5
    I have problem with the voice transmission. After accepting a call, there is no sound. Hatt someone has an idea.
    There are also errors in loog.
    my Loog:
    06:44:06.109 Call::Terminate [CM503008]: Call(63): Call is terminated
    06:44:06.078 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for DID:697478 forwards to DN:81
    06:44:06.078 LineCfg::getInboundTarget [CM503009]: DID rule (697478) is applied to call from sip:01787233xxx@server.rohr-net.eu:5060 to 697478
    06:44:06.078 LineCfg::getInboundTarget Looking for inbound target: called=697478; caller=01787233xxx
    06:42:57.437 CallLeg::eek:nConfirmed Session 55659 of leg C:63.1 is confirmed
    06:42:57.343 CallCtrl::eek:nLegConnected [CM503007]: Call(63): Device joined: sip:15@172.20.0.250:5060
    06:42:57.343 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for DID:697478 forwards to DN:81
    06:42:57.343 LineCfg::getInboundTarget [CM503009]: DID rule (697478) is applied to call from sip:01787233xxx@server.rohr-net.eu:5060 to 697478
    06:42:57.343 LineCfg::getInboundTarget Looking for inbound target: called=697478; caller=0178723xxxx
    06:42:57.312 CallCtrl::eek:nLegConnected [CM503007]: Call(63): Device joined: sip:10010@172.20.0.251:5060
    06:42:57.281 MediaServerReporting::SetRemoteParty [MS210003] C:63.1:Answer provided. Connection(transcoding mode):172.20.0.1:7244(7245)
    06:42:54.718 Extension::printEndpointInfo [CM505001]: Ext.15: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces,
    able-no-sdp, recvonly] UserAgent: [S450 IP021230000000] Transport: [sip:172.20.0.1:5060]
    06:42:54.718 CallCtrl::eek:nAnsweredCall [CM503002]: Call(63): Alerting sip:15@172.20.0.250:5060
    06:42:54.015 MediaServerReporting::InitEndPoint [MS003005] C:63.3: Failed to create Endpoint: (destination=172.20.0.250)
    EndPoint: ID=0000007D@(LOCAL)
    LOGID=C:63.3 Status: MSEP_FAILED
    RTP:172.20.0.1:7248
    RTCP:172.20.0.1:7249
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    NOT SET
    101:telephony-event
    Party ptime:20
    Party RTP:0.0.0.0:0
    Party RTCP:0.0.0.0:0
    Decoders:
    [empty]
    06:42:54.015 MediaServerReporting::InitEndPoint [MS003003] C:63.3: RTCP socket 172.20.0.1:7249 binding failed with error code 10048
    06:42:54.000 MediaServerReporting::InitEndPoint [MS003005] C:63.2: Failed to create Endpoint: (destination=172.20.0.250)
    EndPoint: ID=0000007C@(LOCAL)
    LOGID=C:63.2 Status: MSEP_FAILED
    RTP:172.20.0.1:7246
    RTCP:172.20.0.1:7247
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    NOT SET
    101:telephony-event
    Party ptime:20
    Party RTP:0.0.0.0:0
    Decoders:
    [empty]
    06:42:54.000 MediaServerReporting::InitEndPoint [MS003003] C:63.2: RTCP socket 172.20.0.1:7247 binding failed with error code 10048
    06:42:53.968 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(63): Calling: RingAll81:15Ext.1512Ext.12@[Dev:sip:15@172.20.0.250:5060, Dev:sip:12@172.20.0.250:5060]
    06:42:53.968 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:81@server.rohr-net.eu:5060]
    06:42:53.968 MediaServerReporting::SetRemoteParty [MS210000] C:63.1:Offer received. RTP connection: 172.20.0.251:4934(4935)
    06:42:53.968 CallLeg::setRemoteSdp Remote SDP is set for legC:63.1
    06:42:53.968 Line::printEndpointInfo [CM505002]: Gateway:[ISDN] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite,
    replaces, able-no-sdp, recvonly] UserAgent: [Patton SN4552 2BIS EUI MxSF v3.2.8.45 00A0BA03BEB1 R4.2 2008-05-15 SIP] Transport: [sip:172.20.0.1:5060]
    06:42:53.968 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for DID:697478 forwards to DN:81
    06:42:53.968 LineCfg::getInboundTarget [CM503009]: DID rule (697478) is applied to call from sip:01787233xxx@server.rohr-net.eu:5060 to 697478
    06:42:53.968 LineCfg::getInboundTarget Looking for inbound target: called=697478; caller=01787233xxx
    06:42:53.906 CallCtrl::eek:nIncomingCall [CM503001]: Call(63): Incoming call from 01787233xxx@(Ln.10010@ISDN) to [sip:81@server.rohr-net.eu:5060]
    06:42:53.906 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for DID:697478 forwards to DN:81
    06:42:53.906 LineCfg::getInboundTarget [CM503009]: DID rule (697478) is applied to call from sip:01787233xxx@server.rohr-net.eu:5060 to 697478
    06:42:53.906 LineCfg::getInboundTarget Looking for inbound target: called=697478; caller=01787233xxx
    06:42:53.890 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:10010@172.20.0.1 SIP/2.0
    Via: SIP/2.0/UDP 172.20.0.251:5060;branch=z9hG4bKee04f41f1
    Max-Forwards: 70
    Route: [sip:172.20.0.1;lr]
    Contact: [sip:01787233xxx@172.20.0.251:5060]
    To: [sip:697478@172.20.0.1]
    From: [sip:01787233xxx@172.20.0.1];tag=d8019aa0efb2bf7
    Call-ID: c5186b8e0b5eeeab65d92ad4b21a844b@172.20.0.1
    CSeq: 542781415 INVITE
    Session-Expires: 1800
    Proxy-Authorization: Digest response="ee34ad6e96d2a06d3a0c7ae4857fe35d",username="10010",realm="3CXPhoneSystem",nonce="12862039373:603a3fa58f1a4b9a3a07833d38390038",algorithm=MD5,uri="sip:10010@172.20.0.1"
    Supported: timer, replaces
    User-Agent: Patton SN4552 2BIS EUI MxSF v3.2.8.45 00A0BA03BEB1 R4.2 2008-05-15 SIP
    Content-Length: 0
    Remote-Party-ID: [sip:697478@172.20.0.1];party=called
  2. Henk
    Henk Member
    Nov 13, 2007
    250
    Lets start to get a solid ground.
    Extension to extension dialing does that work?
    Extension to external (not an extension) does that work?
    H.
  3. mp3joker
    Aug 1, 2008
    5
    Hello
    First, it touches only incoming calls my problem, outgoing go without any problems. As client hangs a Siemens Gigaset S450IP at the 3CX. I have a 4552 Patton V4.2 as an ISDN (T-Com Germany) at the 3CX is connected and locally depends on the network, as well as the Siemens Gigaset too. In addition, I have a 4114 V4.2 Patton with two Lines (Akado Russia) via VPN to the 3CX connected with have the same symptoms.
  4. mp3joker
    Aug 1, 2008
    5
    I had the error now when calling on the voice recorder. So should the error actually between Patton and 3CX to search.
    PS my router is a Draytek 2800 at DE and a 2910 at RUS.
    15:42:47.359 MediaServerReporting::RTPReceiver [MS105000] C:68.2: No RTP packets were received:remoteAddr=127.0.0.1:40612,extAddr=0.0.0.0:0,localAddr=127.0.0.1:7268
    15:42:46.781 Call::Terminate [CM503008]: Call(68): Call is terminated
    15:42:46.734 Call::Terminate [CM503008]: Call(68): Call is terminated
    15:42:46.703 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for DID:91381 forwards to VM:13
    15:42:46.703 LineCfg::getInboundTarget [CM503009]: DID rule (91381) is applied to call from sip:01787233xxx@server.rohr-net.eu:5060 to 91381
    15:42:46.703 LineCfg::getInboundTarget Looking for inbound target: called=91381; caller=01787233xxx
    15:41:59.109 CallLeg::eek:nConfirmed Session 67758 of leg C:68.1 is confirmed
    15:41:58.984 CallCtrl::eek:nLegConnected [CM503007]: Call(68): Device joined: sip:99@127.0.0.1:40600;rinstance=9b656b49be7ee01a
    15:41:58.984 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for DID:91381 forwards to VM:13
    15:41:58.984 LineCfg::getInboundTarget [CM503009]: DID rule (91381) is applied to call from sip:01787233xxx@server.rohr-net.eu:5060 to 91381
    15:41:58.984 LineCfg::getInboundTarget Looking for inbound target: called=91381; caller=01787233xxx
    15:41:58.953 CallCtrl::eek:nLegConnected [CM503007]: Call(68): Device joined: sip:10010@172.20.0.251:5060
    15:41:58.953 MediaServerReporting::SetRemoteParty [MS210003] C:68.1:Answer provided. Connection(transcoding mode):172.20.0.1:7266(7267)
    15:41:58.953 MediaServerReporting::SetRemoteParty [MS210001] C:68.2:Answer received. RTP connection: 127.0.0.1:40612(40613)
    15:41:58.953 CallLeg::setRemoteSdp Remote SDP is set for legC:68.2
    15:41:58.953 Extension::printEndpointInfo [CM505001]: Ext.99: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] Transport: [sip:127.0.0.1:5060]
    15:41:58.953 CallCtrl::eek:nAnsweredCall [CM503002]: Call(68): Alerting sip:99@127.0.0.1:40600;rinstance=9b656b49be7ee01a
    15:41:58.453 MediaServerReporting::SetRemoteParty [MS210002] C:68.2:Offer provided. Connection(transcoding mode): 127.0.0.1:7268(7269)
    15:41:58.421 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(68): Calling: Ext:Ext.99@[Dev:sip:99@127.0.0.1:40600;rinstance=9b656b49be7ee01a]
    15:41:58.421 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:13@server.rohr-net.eu:5060;user=vmail]
    15:41:58.421 MediaServerReporting::SetRemoteParty [MS210000] C:68.1:Offer received. RTP connection: 172.20.0.251:4944(4945)
    15:41:58.421 CallLeg::setRemoteSdp Remote SDP is set for legC:68.1
    15:41:58.421 Line::printEndpointInfo [CM505002]: Gateway:[ISDN] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Patton SN4552 2BIS EUI MxSF v3.2.8.45 00A0BA03BEB1 R4.2 2008-05-15 SIP] Transport: [sip:172.20.0.1:5060]
    15:41:58.421 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for DID:91381 forwards to VM:13
    15:41:58.421 LineCfg::getInboundTarget [CM503009]: DID rule (91381) is applied to call from sip:01787233xxx@server.rohr-net.eu:5060 to 91381
    15:41:58.421 LineCfg::getInboundTarget Looking for inbound target: called=91381; caller=01787233xxx
    15:41:58.296 CallCtrl::eek:nIncomingCall [CM503001]: Call(68): Incoming call from 01787233xxx@(Ln.10010@ISDN) to [sip:13@server.rohr-net.eu:5060;user=vmail]
    15:41:58.296 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for DID:91381 forwards to VM:13
    15:41:58.296 LineCfg::getInboundTarget [CM503009]: DID rule (91381) is applied to call from sip:01787233xxx@server.rohr-net.eu:5060 to 91381
    15:41:58.296 LineCfg::getInboundTarget Looking for inbound target: called=91381; caller=01787233xxx
    15:41:58.281 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    Via: SIP/2.0/UDP 172.20.0.251:5060;branch=z9hG4bKea8398789
    Max-Forwards: 70
    To: [sip:91381@172.20.0.1]
    From: [sip:01787233xxx@172.20.0.1];tag=79cd78051f4b880
    Call-ID: 510bdeb5e36cb10fdaa657c2f65728b1@172.20.0.1
    CSeq: 921299179 INVITE
    Proxy-Authorization: Digest response="09c9b78b0b3e1369e17922ce715b03e7",username="10010",realm="3CXPhoneSystem",nonce="12862071717:67999e423e4bad7d5af9a6fb20dd5f2a",algorithm=MD5,uri="sip:10010@172.20.0.1"
    Content-Length: 0
    Remote-Party-ID: [sip:91381@172.20.0.1];party=called
  5. stekicar
    May 2, 2008
    15
    Check "PBX delivers audio" option in Line Management for your PSTN-to-IP adapter. I had the same problem (not being able to hear voice on inbound calls) and this fixed it.
  6. Anonymous
    Anonymous Guest
    To get technical support on this one, you can contact our technical support (This requires commercial edition with support package). If you have a commercial edition, but no support package, you can purchase one here:
    https://erp.3cx.com/orderform/support.aspx
  7. mp3joker
    Aug 1, 2008
    5
    Hallo,
    I have monent nor the free editon and wanted to first see how it runs before I invest
    "PBX delivers audio" is off to both Patton
    Has anyone difference in the Siemens Gigaset use at the 3CX?
    What does this error message? I do not even have her another Snom VOIP Phone to the pbx and this seems to work.
    11:36:26.484 MediaServerReporting::InitEndPoint [MS003005] C:10.1: Failed to create Endpoint: (destination=172.20.0.241)
    EndPoint: ID=00000013@(LOCAL)
    LOGID=C:10.1 Status: MSEP_FAILED
    RTP:172.20.0.1:7036
    RTCP:172.20.0.1:7037
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    NOT SET
    101:telephony-event
    Party ptime:20
    Party RTP:0.0.0.0:0
    Decoders:
    [empty]
  8. mp3joker
    Aug 1, 2008
    5
    In the meantime, I have the error in your response so far can I consider it certainly appears that there was the Siemens Gigaset IP. Did anyone else experience this? Or I am the only one with the Gigaset makes problems on 3CX? Wen also someone in use, and thus has no problems it would be nice if he would post FW version.
    Michael
