NO VOICEMAIL AFTER UPGRADE TO V5
Discussion in '3CX Phone System - General' started by tjabaut, Dec 13, 2007.
  1. tjabaut
    tjabaut New Member
    Jul 24, 2007
    123
    I am not able to use voicemail since upgrading to v5.
    If the receptionist answers the phone and transfers to the extension of a person that is not in the office it rings the office extension for the alloted time. If I monitor in the server log I see the connection attempt. then after the timeout perion (when it should forward to vm) I see the connection with the extension drop, but as a caller I am still left on hold, and the vm server does not pick up.
    On a side note is there anyway to transfer directly to vm (for a receptionist) if one knows the intended party is out of the office?
  2. nateb
    Oct 19, 2007
    68
    voice mail fix
    ok , to fix it, manage lines, edit gateway / provider properties, then edit Gateway capabilities , check supports re-invite , and supports replace header.
    That Fixed it for me!!
