No Voicemail after upgrade to v7
Discussion in '3CX Phone System - General' started by zebrafilm, Jan 30, 2009.
  1. zebrafilm
    May 12, 2008
    11
    After running v6 for a long time on a testbox I decide to start using 3CX as the main PBX.
    I made a backup of v6(latest version), uninstalled, installed V7 and restored the backup.
    Alle extension came backup so everything seemed fine.
    I have added Phones, gateways and ATA adapters and it all works.
    What doesn't work is the voicemail and the digital receptionist that used to work fine in V6.
    When I dial 999 from an extensions the log shows:
    15:22:28.030 [CM503015]: Call(98): Attempt to reach <sip:999@192.168.1.3:5060> failed. Reason: Not Registered
    Calling 800 (my DR) gives the same error.
    Did I miss something? Please advice.
    Bastiaan
  2. ansu2723
    Nov 23, 2008
    29
    I had great problems when I tried to install the v7 on the same machine as v6 was installed. I had the same problem. I tried to get back the settings from v6 but i got a lot of errors. It ended with cleaning the whole computer from v6 an installing the v7 from scratch.
  3. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    What is your configuration?
    IIS, XP, 2003, 2008?
  4. Henk
    Henk Member
    Nov 13, 2007
    250
    Have you restarted the machine after the new install?
    I just done two upgrades and both worked excellent.
  5. zebrafilm
    May 12, 2008
    11
    I did it the hard way and reinstalled a virgin v7. After setting up everything again, it works like before.
    Thanks for the help here.
