no way to place outbound calls on version 3790
Discussion in '3CX Phone System - General' started by aguilar, Jan 13, 2008.
  1. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    all lines are registered, can make calls from extension to extension, pass the firewall test ok, can get inbound calls, everything is working except outbound calls with an especific provider and with other works fine.
    10:16:44.179 StunClient::eek:nInitTests :[CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 64.69.76.23:3478 over Transport 192.168.1.88:5060
    10:15:29.602 Call::Terminate :[CM503008]: Call(5): Call is terminated
    10:15:29.583 Call::RouteFailed :[CM503014]: Call(5): Attempt to reach [sip:855231921@serv] failed. Reason: No Answer
    10:15:29.582 CallLeg::eek:nFailure :[CM503003]: Call(5): Call to sip:55231921@asbw.alestravoip.com:5060 has failed; Cause: 408 Request Timeout; internal
    10:14:57.299 CallCtrl::eek:nSelectRouteReq :[CM503004]: Call(5): Calling: VoIPline:10002@[Dev:sip:5550252312@asbw.alestravoip.com:5060]
    10:14:57.269 CallCtrl::eek:nIncomingCall :[CM503001]: Call(5): Incoming call from Ext.111 to [sip:855231921@serv]
    best regards
  2. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    any clue?
  3. simones181170
    Dec 4, 2007
    51
    check the settings of router and firewall
  4. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    i already did, the settings are just the same as in version 3.1 and the firewall test pass everything ok
