no way to search??
Discussion in '3CX Phone System - General' started by aguilar, Jan 22, 2008.
  1. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    is not possible to search the forums posts?
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    The searching function seems had been disabled. Hopes it can be enable soon.
  3. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    I hope so, thanks for the reply Ricky
  4. npyt
    Hello, I was just trying to find a solution for a problem with the SIPURA 3102, and thus needed to search this site also... and thus I found a great way to search the 3Cx site/forum .. and found what seems to be the solution to my sipura problem..
    To search this forum site:
    1) Open up google: http://www.google.com
    2) in the search box type the following text> site:www.3cx.com your_search_text
    Example: site:www.3cx.com 3102 error
    Results: 3Cx Forum posts discussing the sipura 3102 dial out problems...
    saludos,
    Nico
  5. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    That work around is great. However, 3CX owned forum in need 3rd party for search engine :!: It should be image issue. Hopes the build-in searching function resumed ASAP.
  6. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    thanks for the work around, works great
    regards
