Noise using Mediant 1000
Discussion in '3CX Phone System - General' started by sunero, Jul 8, 2008.
  1. sunero
    Jul 7, 2008
    11
    I have a Mediant 1000 5.2 with 2 PSTN lines and a Linksys SPA922.
    My problem is noise when going through the Mediant gateway. I have tried to set different values in voice control, Imput gain an packetization time , but it doesn't seems to help.
    When I use my 3CX internal or through a VOIP supplier I don´t have problems with the noise.
    What can I do to make it work?
  2. Anonymous
    Anonymous Guest
    Have you checked the line itself by connecting an analogue phone to it?
    Thanks,
  3. sunero
    Jul 7, 2008
    11
    I have had a normal hardware pbx on the lines without any trouble. Is there any known problems connectiong a Mediant 1000 BRI 4 to the 3CX?
  4. Anonymous
    Anonymous Guest
    Mediant devices are untested with 3CX so we cannot report any problems at this stage.
    Thanks,
  5. sunero
    Jul 7, 2008
    11
    I know :)
    But if the AudioCodes MP 114 is working then it should be possibel to use the Mediant. I know it is working with the AudioCodes MediaPack 40x.
    Maybe anyone have tried the Mediant 1000 on the 3CX and have some hints ?
  6. sunero
    Jul 7, 2008
    11
    Hi, the reason for the noise was the G711U-law codes. The right on was the G711A-law.
