nokia 3250
Discussion in '3CX Phone System - General' started by aguilar, Jan 31, 2008.
  1. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hello
    i just install an extension using a Nokia 3250 with Fring, the registration was ok i just have a delay problem (it is configured as binded)
    does anyone knows a workaround?
    regards
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    turn off "PBX delivers audio" option and turn on supports re-INVITE in extension configuration(Nokia 3250). Click OK
    Make a call to another extension with the same configuration ("PBX delivers audio" off and "supports re-INVITE" on and extension must be resided in the same LAN with PBX)
    Do you have the same delay or it works better?
  3. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hello Sy
    thanks for the reply, seems a little bit better but will make some more tests
    regards
  4. SY
    3CX Support
    Jan 26, 2007
    1,825
    Hi Alejandro,
    I'm trying to ask you about differences between "bound" (PBX deliver audio) and configuration I specified above.
  5. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hi Stepan
    i will be able to give my feedback just on monday because someone just took the phone over the weekend, sorry about that
    best regards
