Nokia e61 - Help me
Discussion in '3CX Phone System - General' started by m.serraglio, Feb 19, 2008.
  1. m.serraglio
    Feb 15, 2008
    7
    Please help!
    I tried to set my nokia e61 but failed to register in my switchboard 3cx ...
    Someone helps me to configure it?
    Marco Serraglio
  2. alicic
    alicic New Member
    Oct 3, 2007
    119
    Here it comes,
    Create an extension in 3cx for example "100" and password: "100"
    after that enter the settings in your phone
    1. Go to "Tools" and then to "Settings"
    2. Go to "Connection"
    3. Go to "SIP settings"
    4. Add a new default profile
    5. enter the following settings:
    Profile name: 3cx
    Service profile: IETF
    Default access point: choose your WLAN access point
    Public user name: your extension@ip from your 3cx-server (Example: 100@192.168.1.1)
    Use compression: No
    Registration: Always on or When needed
    Use security: No
    Proxy server:
    Proxy server address: ip from your 3cx-server (example: 192.168.1.1)
    Realm: 3CXPhoneSystem
    User name: your extension (example: 100)
    Password: the password of your extension
    Allow loose routing: Yes
    Transport type: UDP
    Port: 5060
    Registrar server:
    Registrar serv. addr. : ip from your 3cx-server (example: 192.168.1.1)
    Transport type: UDP
    Port: 5060
    Now go back to "Connection" and then to "Internet tel. settings"
    create a new profile:
    SIP profiles: 3cx
    And then it works
  3. m.serraglio
    Feb 15, 2008
    7
    Beautiful ... Work ....
    I now remained only the problem of not being able to dial telephones internal or external number from nokia ....
    What should I do?
    Thanks ,
    Marco Serraglio
  4. alicic
    alicic New Member
    Oct 3, 2007
    119
    Find the option in 3cx - Bind voice to media Server, and unselect this, and it shpul work perfectly
    regards
