NOKIA E61
Discussion in '3CX Phone System - General' started by amygoda, Sep 18, 2006.
  1. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    How can I configure nokia e61 to register on 3CX
    Thank You
  2. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    I've reviewed your product's manual and it seems that the Nokia e61 supports what is called 'net calls'.
    Firstly you will need to connect your phone to the network where your 3CXPhoneSystem is installed. This can be done through a Wireless network, as the e61 supports WLAN connectivity. Perhaps you have already connected your phone to you network in order to browse the internet, read mail and so on.
    Secondly you need to register your phone with the PBX server. Simply create an extension in the 'Add Extension' page and configure your phone to use this extension. The e61 manual describes this process under 'net calls':
    SIP settings go in in:
    Menu > Tools > Settings > Connection > SIP settings
    VoIP settings go in:
    Menu > Tools > Settings > Connection > Internet tel. settings.
    I highly recomend you read this small section in the manual. I cannot give you the exact entries for the right fields as I do not have a e61 handy, but feel free to post again should you encounter any further difficulties.
  3. Anonymous
    Anonymous Guest
    I've tried to register a Nokia E61 to 3CX server but it allways failed.
    22:38:32.656|.\Authorization.cpp(61)|Message5|Authorization|AuthMgr::handle: handle:
    REGISTER sip:192.168.1.20 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bKe837.4df942f1.0
    Via: SIP/2.0/UDP 192.168.1.215:5060;branch=z9hG4bKm098rr1lqhhc6cp8dmeioeu
    Max-Forwards: 69
    Contact: <sip:102@192.168.1.1:5060>;expires=3600
    To: <sip:102@192.168.1.20>
    From: <sip:102@192.168.1.20>;tag=150orr799thc6elidmet
    Call-ID: FPKdX86yoIemWmSthIp5oz4qH3huQE
    CSeq: 1003 REGISTER
    Supported: sec-agree
    Content-Length: 0
  4. meucci
    Mar 1, 2007
  5. beantree
    Sep 12, 2007
    E61(i) - baffled new user
    Can someone who has actually made an E61 work please give me the details of the settings used?
    Also, how do I view the logs in the detail I see in previous posts?
  6. mbs1
    Mar 7, 2007
    35
    hi
    have you looked at this previous post
    http://www.3cx.com/forums/viewtopic.php?t=1488
    may help
    mbs
