Nokia E65 incomming promblem
Discussion in '3CX Phone System - General' started by vijaykumar, Aug 28, 2007.
  1. vijaykumar
    May 23, 2007
    5
    Hi Guys
    I used the settings you offered here for E65, I got the profile registered at last, but my main problem is that i can call out ! but i cannot recieve calls. Any settings i should do in server or on phone. Can any body help me with this.
    Thanks in advance
    Vijay
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please post your console log.
  3. vijaykumar
    May 23, 2007
    5
    This is my Server Log, it is landing to my voice mail.
    15:18:44.643 CallLegImpl::eek:nConnected Call(C:7F): Created audio channel for Ext.103 (10.0.3.98:1372) with Media Server (10.0.3.253:7324)
    15:18:29.486 CallConf::eek:nIncoming Call(C:7F): Incoming call from Ext.103 to sip:106@10.0.3.253
  4. vijaykumar
    May 23, 2007
    5
    Help me please with my E65
    Hi Guys,
    Please help guys..... I am completly blank any settings to be changed.
  5. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi vijaykumar,
    Please provide more details log here maybe help to solved your problem faster.
    Have you done the line configure for inbound call to your E65's extension?
    The option at Lines > Manage> Click the number at Identification column
    Route inbound calls in office hours to : your E65's extension
    Route inbound calls out of office hours to : your E65's extension
    Other Options:
    Answer incoming calls on this line: ticked
    Answer after (seconds): 1
    Maximum simultaneous calls: 1
    You maybe check your E65's setting by reference this post
    http://www.3cx.com/forums/viewtopic.php?t=1488
    Hope this can help to solved your issue. :!:
  6. vijaykumar
    May 23, 2007
    5
    I am sorry i did not get this line,
    "The option at Lines > Manage> Click the number at Identification column
    Route inbound calls out of office hours to : your E65's extension "
    If i configure tha same Ext on my Xlite i can get incomming but on my E65 i am not able to get it even from other local extension.
    I used the same configaration which is posted on this form, after that only i was able to register the line with the server. that was very help full for me.
  7. C51
    C51
    Aug 10, 2007
    18
    what software are you using on your device?
    thanks
    Jordan
