Nokia E65 lost registration
Discussion in 'Windows' started by uniekit, Nov 10, 2008.
  1. uniekit
    Sep 15, 2008
    12
    I Have a nokia E65 and it lost his registration when the phone is not used after +/- 10 min.
    I Don't use a firewall on the W-Lan AP.
    I have the last firmware on the Nokia.
    Have somebody the same problem or can you help me?
    Thx!
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello and welcome,
    do you use wifi or gsm
    any way nokia can not control reregistration time
    but if you use wifi this could be because of wifi coverage
  3. uniekit
    Sep 15, 2008
    12
    Thank you!
    I Use wifi.. the signaal is good. Do you use the nokia e65? en you don't have the same problem?
  4. galal202
    galal202 New Member
    Jun 23, 2008
    235
    I use nokia E61,E61I
    sometimes they do reregistration
    and sometime not
    but any way nokia e61I better faster in network
  5. uniekit
    Sep 15, 2008
    12
    Oké! and do you have experience with the nokia E51? is seems that this version works...
  6. galal202
    galal202 New Member
    Jun 23, 2008
    235
    all nokia are the the same settings
  7. rnoguera
    Oct 25, 2007
    89
    Which WiFi AP are you using?
    We are having the same trouble with Lobometrics.
    On the other hand DLINK seems to do better. Also Ubiquity NanoStation2 is also NOT working fine.
  8. acastrejon
    Mar 5, 2007
    I just bought a E65, Can anyone tell me how Can i connect to 3CX? what software use?
    Thanks in advance foy your help
    Alejandro Castrejon
  9. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello And welcome
    examble ext 50000 on ip 10.0.0.100
    press Tools and Settings then Connection then SIP settings
    Add a new default profile
    enter the following settings
    Profile name: 3cx
    Service profile: IETF
    Default access point: access point you use to connect
    Public user name: 5000@10.0.0.100
    Use compression: No
    Registration: When needed
    Use security: No
    Proxy server:
    Proxy server address: 10.0.0.100
    Realm: 3CXPhoneSystem
    User name: 50000
    Password: Your password
    Allow loose routing: Yes
    Transport type: UDP
    Port: 5060
    Connection then Internet tel settings
    create a new profile:
    SIP profiles: 3cx
    Connection then SIP settings then 3cx
    change Registration set to always on
  10. bradcapo1
    Jul 22, 2009
    This is an interesting post.. thank you for sharing
    taux pret auto - taux pret auto differe selon la rise en compte ... calculent automatiquement le taux pour un prêt automobile donne.
  11. Yakko
    Jun 24, 2009
    5
    I have no problem with my Nokia N95. I Use different access point (ASUS, NETGEAR and linksys) with no problem.
