Nokia E90 Configuration
Discussion in '3CX Phone System - General' started by rodneyeid, Aug 11, 2007.
  1. rodneyeid
    Aug 8, 2007
    18
    CAn anyone help me configure my NOKIA E90 . I have put all the settings but it gives me registration failed
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi rodneyeid,
    Your Nokia E90 connect to local LAN or NAT over the Internet? Nokia E90 can working fine at LAN. However, it maybe unable to registered to 3CX via NAT over Internet.
    Normally, all the SIP clients will work if all the following fields are correct.
    User Name: XXX
    Password: ***
    Authorization User Name: XXX ( same as user name)
    SIP Server Name: xxx.xxx.xxx.xxx or sip.xxxxxxx.com
    Outbound Sever: xxx.xxx.xxx.xxx or sip.xxxxxxx.com
    STUN Server: stun.3cx.com (disable if the phone in use at LAN)
    Regards,
  3. rodneyeid
    Aug 8, 2007
    18
    i cant find a place to put my STUN server on Nokia E90
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi rodneyeid,
    It should be support STUN. I also cannot found any stun setting as well. Please try to ask help from Nokia CS.
  5. rodneyeid
    Aug 8, 2007
    18
    what should i put in the the 3cx server settings so that it works on lan
  6. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi rodneyeid,
    Please try following steps. The green higlight may be help to input the correct data.
    Session initiation protocol (SIP) settings
    Select > Tools > Settings > Connection > SIP settings.
    Session initiation protocols (SIP) are used for creating, modifying, and terminating certain types of communication sessions
    with one or more participants (network service). SIP profiles include settings for these sessions. The SIP profile used by default
    for a communication session is underlined.
    To create a SIP profile, select Options > Add new > Use default profile or Use existing profile.
    To select the SIP profile you want to use by default for communication sessions, select Options > Default profile.
    Edit SIP profiles
    Select SIP settings > Options > Add new or Edit, and select from the following:
    • Profile name — Enter a name for the SIP profile.
    • Service profile — Select IETF or Nokia 3GPP.
    • Default access point — Select the access point to use for the internet connection.
    • Public user name — Enter your user name received from your service provider.
    • Use compression — Select if compression is used.
    • Registration — Select the registration mode.
    • Use security — Select if security negotiation is used.
    • Proxy server — Enter the proxy server settings for this SIP profile.
    • Registrar server — Enter the registration server settings for this SIP profile.The settings available for editing may vary.
    Edit registration servers
    Select SIP settings > Options > Add new or Edit > Registrar server.
    Select from the following:
    • Registrar server address — Enter the 3CX host name or 3CX IP address of the registrar server in use.
    • Realm — Enter the registrar server realm.
    • User name and Password — Enter your user name 3CX EXT and 3CX EXT password for the registrar server.
    • Transport type — Select UDP or TCP.
    • Port — Enter the port number 5060 of the registrar server.
