nokia N80
Discussion in '3CX Phone System - General' started by cristina, May 8, 2008.
  1. cristina
    Apr 23, 2008
    12
    I want to use 3cx to call between 2 nokia N80 in the same subnet. I already got it with Asterisk, but i would like to try 3cx now.
    I have a registrer error when setting the client in the phone. Does someone know how to do it?
  2. coelhopsi
    May 7, 2008
    84
    How are you configuring the N80? Did you use "3CXPhoneSystem" as the Realm of the account?
    The following link contains the configuration for Nokia E65. It should be pretty similar to that:
    http://www.3cx.com/sip-phones/nokia-e65.html
  3. cristina
    Apr 23, 2008
    12
    Thank you for your help!
  4. arpa
    Feb 14, 2008
    35
    I don't know if at your phone you will have the same problem as i describe in an other topic . In my case i have to uncheck the "Supports Re-Invite" option (from Extension number / Other options) to work without restarting my Nokia E70, when i answer a call forwarded to my ringing group (that my Nokia belongs to), from a Digital Receptionist.
