Nokia N95
Discussion in '3CX Phone System - General' started by malcm, Mar 27, 2008.
  1. malcm
    May 27, 2007
    8
    Has any body out there actually got this phone to register on 3CX.
    My N95 will register with nearly every other provider but will in no way register on 3CX.
    I am certain my settings are correct but if anyones got it connected I'd appreciate a copy of your settings.
  2. BJReplay
    BJReplay New Member
    Oct 31, 2007
    133
    Yes (ok, not an N95, but an N82), using the info here: http://www.3cx.com/sip-phones/nokia-e65.html.
    The most important point is: In the “Realm” field enter “3CXPhoneSystem.
    Also important is changing the transport to UDP.
    I didn't bother setting up the proxy settings, just the registrar settings, but others have required both to be set up.
    I also have a configuration on my 3CX server where the user name is not the same as the extension number, so in the instructions where it says under proxy / registrar to enter extension number for the user name, I entered user name. This won't be a problem for most people who have a user name the same as the extension.
    Finally, in order to get two way audio working, I also needed to set up the stun settings in the phone, using the Nokia supplied SIP VoIP Settings application: http://www.forum.nokia.com/info/sw....e606b80709/SIP_VoIP_Settings_v1_0_en.zip.html. You probably won't need this is your 3CX server and your N95 are on the same private subnet - however, in my case, my N82 is behind a NAT firewall on one private IP, and my 3CX server is behind a separate NAT firewall on a separate IP, so my calls needed to traverse two NAT firewalls - without the Nokia SIP VoIP Settings (specifically setting up a STUN server on the N82), the N82 was sending a private IP in the SIP messages to 3CX, so obviously 3CX was unable to route audio over an RTP stream to a private IP.
    Now that it is working, it works really well - my desk phone (SPA941) and my mobile ring simultaneously when someone calls my extension or direct indial line, and I can take the call on whichever is more convenient.
