Nokia SIP step by step setup
Discussion in '3CX Phone System - General' started by nwhitfield, Jul 9, 2010.
  1. nwhitfield
    May 15, 2010
    35
    I've just written a step by step setup guide to using a Nokia phone with the built in SIP client to connect to 3CX, and also how to set up a VPN to solve firewall issues.
    Not sure if I should post the blog URLs on here, but if anyone wants to know the address and can't find it by Googling, let me know.
    Nigel
  2. carolinainnovative
    May 4, 2009
    369
    6
    Whe wouldn't you post it?
  3. nwhitfield
    May 15, 2010
    35
    Well, some forums I'm on have admins that are a bit picky about posting links elsewhere.
    But here you go:
    http://gonedigital.net/2010/07/09/nokia-e72-step-by-step-voip-and-vpn-setup-for-3cx/
    There are a few other bits there about my adventures with 3CX.
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    HOW DARE YOU! :p We only delete useless links, useful guides that help everyone are always welcome. Thank you for your link and I hope it helps a lot of feature users!
  5. nwhitfield
    May 15, 2010
    35
    I've just added another post, which explains how to get message waiting indications on a Nokia SIP phone:
    http://gonedigital.net/2010/07/21/3cx-message-waiting-and-the-nokia-sip-client/
    It's a pity it doesn't make the little voicemail icon light up, rather than arriving like a text message, but still very useful.
