Noob question regarding handsets
Discussion in '3CX Phone System - General' started by FatNakedGuy, Apr 2, 2009.
  1. FatNakedGuy
    Apr 2, 2009
    I have the following handsets available to play with but am not sure if they will work. Can anyone tell me? Thank you!
    Avaya 2410
    Avaya 4406D+
    Avaya IP400 Digital Station 16 port
  2. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    HI
    If they support SIP, they should work yes. Can you post their web interface ? Save in mht format and attach.
    I think you can start from the 2410 since you have them handy. If it supports sip it has no reason why it shouldn't register. You have to try it out - because if they work only with Avaya systems you'll have dysfunctions.
