Not a call
Discussion in '3CX Phone System - General' started by hardsoft, Aug 29, 2009.
  1. hardsoft
    Aug 24, 2009
    Hi all i have problems with my configuration:
    i have installed 3cx phone, 3cx gateway for skype, i have added the pstn line, the line 10000 is green and my 3cx phone calls but without any answer.
    what is the problem?
    help me please
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,528
    71
    Veri brief description provided :mrgreen: Before asking you for log files and details, from your phone try to call gateway Skype sound test. Therefore, supposing the outbound rule is 9, call 9echo123, and see if it "answers".
    Regards
    vali
