not able to call out side
Discussion in '3CX Phone System - General' started by Anonymous, Sep 26, 2006.
  1. Anonymous
    Anonymous Guest
    Thanks for the great product which work in windows itself.
    While configuring i encountered some problem please rectify it.
    I am using fritz box .(ADSL Modem)
    I have installed the PBX, latest version (beta 2) ,
    I configured one sip phone, one sip adaptor and sip soft phone with test account 100,101,102 and I am able make internal calls
    I added the voip provider details, and it is registered.
    In the line status every thing looks ok (green colour) but i am not able to call out side.
    The error which i am getting is given below.
    16:14:45.968 LineImpl::registered Line [#888065010257 @call4communication] has been registered at provider
    16:14:53.500 CallConf::saveCallEvent Incoming c51 "test2"<sip:101@192.168.178.27> <sip:919847803356@192.168.178.27> Incoming call (before routing)
    16:14:53.531 CallConf::saveCallEvent Rejected c51 "test2"<sip:101@192.168.178.27> <sip:919847803356@192.168.178.27> Callee is not resolved or forbidden, sent 404 response
    16:14:53.546 CallConf::saveCallEvent Terminated c51 "test2"<sip:101@192.168.178.27> <sip:919847803356@192.168.178.27> Call ended
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,990
    304
    Prefix not dialed
    Thank you for your nice feedback!
    From the error, it would appear that the number is considered an internal number. Looking at the error:
    the destination number <sip:919847803356@192.168.178.27>does not have a prefix, so it is considered an internal number. Since there is no extension which such a long number the call fails.
    Please check if you dialed a prefix, and if you configured a custom prefix (such as a 9), check your dialing rules. They would need to be adjusted as well.
    Let me know if this helps or if you need more help.
    As a note we are working on an updated beta with much better logging errors and documentation.
    regards,
