Not automatic blind transfert on BLF
Discussion in 'Ideas' started by adigit, Oct 21, 2016.
  1. adigit
    Apr 12, 2010
    It will be nice to have attended transfer when pushing BLF instead of blind transfer because it can be use for both transfers.
    If you want a blind transfer you just need to hang after pushing BLF key, without talking !
  2. 12494
    12494 Member
    Apr 16, 2010
    306
    31
    I don't know what phones you use but Yealinks have a configuration option where you can change this behavior between blind and attended transfer.
    Allen
