Not CONNECTED in the cloud server
Discussion in 'iOS' started by chikara sugiyama, Oct 26, 2014.
  1. chikara sugiyama
    Jun 15, 2014
    22
    Hello
    A cloud server only when using it will be "Not CONNECTED".
    It is not possible to confirm the history and status.
    In Android and Windows it is no problem.
    It is no problem in the normal stand-alone version.
    iPhone is "iOS 8.1".
    Thank you for your attention.
  2. IliasL_3CX
    3CX Support
    Jun 2, 2014
    74
    Hi there,
    Are you using the latest version of the 3CX Phone for iPhone? Furthermore are ports 80/443 open on your firewall.
    Regards
