Not connected
Discussion in '3CX Phone System - General' started by Balaji, Oct 7, 2017.
  1. Balaji
    Oct 7, 2017
    Hi I am new for this program Just saw the videos and try to connect the 3CX installer. No problem in the installation. Post installation I could not connect, the network not available in the phone screen. I using windows 10. Need help.
      File size:
      77 KB
      8
    11,095
    327
    Might be a presence issue caused by ports not being open at the server end. I assume you have a 3CX PBX that you are connecting with and a configuration file was sent to the PC.
    Are you able to place calls?
  3. agp
    agp 3CX Team
    Aug 19, 2015
    151
    22
    Hi @Balaji ,
    As leejor said, assuming that you have a 3CX PBX installed and configured:
    • Download and install the V15 client
    • Download and run the provisioning file for the extension you are trying to configure.
