Not connected
Discussion in 'Windows' started by galal202, Jun 23, 2008.
  1. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello
    I did all 3CX voip client configuration
    it always says "Not connected"
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello Matt
    The server is local and i can ping it
    also when I switch to desk phone mode I see all conection status
    Thank You
  3. galal202
    galal202 New Member
    Jun 23, 2008
    235
    No it's not the free version
  4. galal202
    galal202 New Member
    Jun 23, 2008
    235
    This issue still running
  5. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Check credentials. Authentication Password (not VM PIN!) should be used on VoIP Client.
  6. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    If you use latest VOIP client version upgrade your server to the latest version
  7. galal202
    galal202 New Member
    Jun 23, 2008
    235
    thank you ,now it works with me
