Not Found when calling 08xx numbers
Discussion in '3CX Phone System - General' started by oliverm, May 6, 2010.
  1. oliverm
    Mar 10, 2009
    79
    we have a problem whereby when we call any number starting 08 (ie 0870, 0845, 0871 etc) the phone beeps and says "Not Found 90871123456" (insert the number at the end there.
    Is that likely to be a 3CX set up issue or an issue with the SIP trunk provider? I'm guessing the latter as we don't have any problems calling other numbers and they seem a bit clueless.
    Olly
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    It sounds like some kind of call issue. Just to be sure and if they are available, Could you kindly post the detailed verbose logs so we may have a look.
  3. oliverm
    Mar 10, 2009
    79
    Where can I find those logs ? (total newbie)
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    No problem, Im glad to see you asking. Ill break it down into steps.
    1. From the 3CX Console > Settings > Advanced > Logging Level , please change the option to 'Verbose'.
    2. Restart the 3CX machine.
    3. Allow a couple of minutes for the 3CX server to initialise and ensure the required extensions and lines are appearing as registered before proceeding.
    4. Reproduce the issue.
    5. If you look at the management console, there is an option called "server activity log" 5th one down from "port trunk status".
    6. There is a button at the top called copy selected text.
    7. Come onto this forum and paste it here using [-code] and [-/code] tags removing the -.
    EDIT: If your having trouble finding it, ill post screenshots, just ask for them!
  5. oliverm
    Mar 10, 2009
    79
    Code:
    18:21:23.287  [CM503020]: Normal call termination. Reason: Not found
    18:21:23.287  [CM503016]: Call(1): Attempt to reach <sip:908453073443@10.1.39.6:5060> failed. Reason: Not Found
    18:21:23.287  [CM503003]: Call(1): Call to sip:08453073443@spitfiretsp.net:5060 has failed; Cause: 404 Spitfire CHKto DENIED; warning: Noisy feedback tells:  pid=2608 req_src_ip=83.218.143.18 req_src_port=5060 in_uri=sip:08453073443@spitfiretsp.net:5060 out_uri=sip:08453073443@spitfiretsp.net:5060 via_cnt==1; from IP:83.218.143.18:5060
    18:21:22.709  [CM503025]: Call(1): Calling VoIPline:08453073443@(Ln.10000@Spitfire)@[Dev:sip:441273907980@spitfiretsp.net:5060]
    18:21:22.677  [MS210002] C:1.2:Offer provided. Connection(transcoding mode): 109.238.76.251:52701(52702)
    18:21:22.506  [CM503004]: Call(1): Route 1: VoIPline:08453073443@(Ln.10000@Spitfire)@[Dev:sip:441273907980@spitfiretsp.net:5060]
    18:21:22.412  [MS210000] C:1.1:Offer received. RTP connection: 10.1.39.47:40000(40001)
    18:21:22.396  [CM503010]: Making route(s) to <sip:908453073443@10.1.39.6:5060>
    18:21:22.396  Remote SDP is set for legC:1.1
    18:21:22.396  [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 4.0.10858.0] PBX contact: [sip:100@10.1.39.6:5060]
    18:21:22.381  [CM503001]: Call(1): Incoming call from Ext.100 to <sip:908453073443@10.1.39.6:5060>
    18:21:22.177  [CM500002]: Info on incoming INVITE:
      INVITE sip:908453073443@10.1.39.6:5060 SIP/2.0
      Via: SIP/2.0/UDP 10.1.39.47:50791;branch=z9hG4bK-d8754z-d57467643c6fdd16-1---d8754z-;rport=50791
      Max-Forwards: 70
      Contact: <sip:100@10.1.39.47:50791;rinstance=deb2444ea267cd50>
      To: <sip:908453073443@10.1.39.6:5060>
      From: "08453073443"<sip:100@10.1.39.6:5060>;tag=761e4b50
      Call-ID: ODlhZmE2YTIyODk1ZjQ1MGI2YTExMjU2OTgyYjVmZjg.
      CSeq: 2 INVITE
      Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
      Proxy-Authorization: Digest username="100",realm="3CXPhoneSystem",nonce="414d535c01f38b9143:64053bed0f23463e5e32eabba3b1a688",uri="sip:908453073443@10.1.39.6:5060",response="af6e338ea7f06ac8da3ab9a071c11152",algorithm=MD5
      Supported: replaces
      User-Agent: 3CXPhone 4.0.10858.0
      Content-Length: 0
  6. oliverm
    Mar 10, 2009
    79
    Any ideas?
    This is causing us real issues now.
  7. leejor
    10,731
    277
    If calls through to other numbers work fine, and the format of the 08 numbers you are sending is correct. Then i would have to assume that your provider is blocking calls to those numbers. I would speak to them. 08 numbers are charged at a higher rate in the UK, are they not?
