Not getting (3CX)sipgate to (Snom)sipgate audio to work
Discussion in '3CX Phone System - General' started by MajicF, Aug 25, 2008.
  1. MajicF
    Aug 16, 2008
    7
    I've got 3CX set up with two VOIP providers. One is sipgate, and the other is gradwell.
    I'm having problems when calling another phone that is on sipgate through 3CX. The call connects, but we can't hear each other. Same occurs if they call me..
    These are what works and doesn't.
    Outgoing
    Snom 360 -> 3CX (sipgate) -> sipgate (snom 320 or 360) = Connects, can't hear each other
    Softphone -> 3CX (sipgate) -> sipgate (snom 320 or 360) = Connects, can't hear each other
    Snom 360 -> 3CX (sipgate) -> sipgate (softphone) = Works
    Snom 360 -> 3CX (gradwell) -> sipgate (snom 320 or 360) = Works
    SoftPhone -> TrixBox (sipgate) -> sipgate (snom 320 or 360) = Works
    Mobile -> sipgate (snom 320 or 360) = Works
    Incoming
    Sipgate (snom 320 or 360) -> 3CX(sipgate) -> Snom 360 = Connects, can't hear each other
    Sipgate (snom 320 or 360) -> 3CX(gradwell) -> Snom 360 = Works
    Sipgate (Softphone) -> 3CX(sipgate) -> Snom 360 = Works
    sipgate (snom 320 or 360) -> Mobile = Works
    Internal
    Snom 360 -> 3CX -> Snom 320 or 360 = Works
    Direct
    Sipgate (Snom 360) -> Sipgate (Snom 360) = Works
    I've tried all sorts of codec changes etc, and just can't get it to work properly. It would indicate a problem with the configuration of the snom phones, but tried all sorts of stuff.
    Anyone have any ideas. I've tried to search these forums for some help, but can't filter anything out useful.
  2. MajicF
    Aug 16, 2008
    7
    Anyone have any suggestions for this? I really can't see whats wrong. Seems like a problem only when using Sipgate, Snom and 3CX in combination.
  3. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    To get technical support on this one, you can contact our technical support
    (This requires commercial edition with support package). If you have a
    commercial edition, but no support package, you can purchase one here:
    https://erp.3cx.com/orderform/support.aspx
  4. MajicF
    Aug 16, 2008
    7
    I don't really want to spend out on a license for software that isn't working. Is this a known bug or configuration issue that you are aware of?
    If its something I'm doing, then I'd likely purchase the software. But if its a fault with 3CX and sipgate, then I'm not obviously going to.
