"Not implemented" message on international call - Windows
Discussion in '3CX Phone System - General' started by ronsatkirit, Oct 1, 2013.
  1. ronsatkirit
    Oct 1, 2013
    Hello-
    International calls from all Windows clients in our system are failing with the message "not implemented". International calls from SIP phones work, even when the extensions are the same as the failing Windows clients.
    I don't see any settings related to this in either the Windows client settings or the 3CX system settings.
    Using 3CX Phone System v11 with 3CXPhone for Windows 6.
    Any suggestions to enable international calls on the Windows clients?
    Thanks,
    Ron
  2. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    Re: "Not implemented" message on international call - Window
    on softphone go to preferences and unselect "alow video calls" or disable video on trunk in 3cx management console, then try again
