Not numeric auth ID? No registration...
Discussion in '3CX Phone System - General' started by sigmacom, Jan 30, 2007.
  1. sigmacom
    Jan 28, 2007
    Extremely serious bug IMHO:
    The system will not accept text as Auth ID for an extension line account. ONLY numerical.
    If this is happening also in VoIP providers accounts, it's a disaster for me... (I have an account with text username).
    Any solution?
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    I can confirm that we have several accounts using alphanumeric credentials, and all authenticate with the voip provider successfully, and successfully receive and send calls.
    I have also checked authentication for extensions. and have confirmed that authentication with alphanumeric credentials is NOT working correctly.
    Will be fixed in an upcoming release, but since the phones are typically in the user's control, the severity of this issue is not so high.
    Nevertheless scheduled for a fix, hopefully with the next release.
  3. xc99tour
    Jan 2, 2007
    37
    How about ext. with out a password? Can you support that?
  4. sigmacom
    Jan 28, 2007
    Thaaaanks! :D
