Not playing outgoing message when voicemail picks up
Discussion in '3CX Phone System - General' started by isysman, Mar 2, 2009.
  1. isysman
    Feb 25, 2009
    13
    I have configured my voicemail to connect after 14 seconds, I used my Cisco handset to dial in to voicemail settings and record my outgoing message however when I call in from another phone (external line) it doesn't play my message, it just starts with the voicemail options "To record a message press 1."
    Any ideas?
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    What steps did you take from your extension to record this? Did you use option 8 which allows you to change your voice mail greeting ?
    regards
  3. isysman
    Feb 25, 2009
    13
    Well I recorded my message three times and the first two it didn't take but the third time it worked. So problem is resolved now. Thanks for the reply.
  4. mbaltus
    Dec 12, 2008
    66
    naturally you saved the message after recording it (from the top of my head, using '1', after recording the message and pressing the #)?
