Not possible to allow internal call and not external
Discussion in '3CX Phone System - General' started by bluetel2, Oct 28, 2010.
  1. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    Hi all,
    maybe it's very very question of noob, but i can't allow internal call for extension and refuse external calls.
    it's with v9 of 3cx system. i know that it's possible for the v8 version.
    Tks advance
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    in the settings for the extension you can disable outbound external calls for each extension (bottom of the page on the Other tab)
  3. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    tks for your reply abc123, but maybe i was not clear. it's for received call from internal or external.
    tks
  4. leejor
    10,731
    277
    Any incoming (external) call only go where you tell it to. If the extension doesn't have a DID number and is not part of a queue or ring group, or someone doesn't dial it from a menu from within an automated attendant, then it should never receive any ,direct, outside calls. However, you won't be able to stop someone from transferring an external call to an extension.
  5. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    Tks leejor for reply, but i search easy mean, like personnalised status, you see. it's not for me but for user, and user who have no administrative rights. i try personnaisez 2 but when i redirect internal to number of extension server said that number don't exist....
    now i'm sure their is no easy mean to do this, and maybe it's request feature.
  6. leejor
    10,731
    277
    Sorry, I'm not really clear on what you are trying to accomplish for them.
