NOT TONE COOMAND
Discussion in '3CX Phone System - General' started by kirimis, Oct 16, 2007.
  1. kirimis
    Oct 16, 2007
    43
    HALLO
    I AM NEW TO THE FAMILY OF 3CX
    I MANAGED TO SET IT UP AND EVERYTHING IS OK INTERNAL AND WITH VOIP GATEWAY. TODAY I TRIED TO CONNECT A LINKSYS SPA-3102 TO PLUG IN AN EXTERNAL LINE.
    THE ONLY PROBLEM I HAVE AND I NEED YOUR HELP IS THAT WHEN CALLING FROM OUTSIDE I HEAR THE PROMPT BUT WHEN I PRESS 1 NOTHING IS HUPPENING. TONE COMMAND DOES NOT WORK FROM EXTERNAL. FROM INTERNAL IS OK. I READ OTHERS HAVING THE SAME PROBLEM IN THE FORUM I TRIED THE SOLUTION GIVEN BUT NOTHING.
    CAN YOU PLEASE HELP ME WITH THAT MODEL SPA-3102?
  2. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    have you visited the following http: //www.3cx.com/voip-gateways/linksys-3102/ - NO LONGER AVAILABLE if not please go through it and see how it works.
  3. kirimis
    Oct 16, 2007
    43
    STILL PROBLEM WITH TONE COMMANDS
    YES I DID FOLLOWED ALL THE INSTRUCTIONS GIVEN. BUT STILL THE PROBLEM EXISTS
  4. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    What country?
    And, by the way, your CapsLock has stuck I suppose :)
