Not working fax
Discussion in '3CX Phone System - General' started by mnemonix, Jan 15, 2008.
  1. mnemonix
    Jan 8, 2008
    13
    Поключили все телефоны все работает дали на телефон номер скажем 103. начинаем через него звонить звонящего слышать, а он нет. Все подключено через Linksys RTP300 факс икщеруе 1270. Помогите настроить работа стоит. :cry:
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Re: Не работает факс
    english ? or portuguese..... please:|
  3. silentfun
    silentfun Member
    Dec 11, 2006
    364
    Translation:
    Poklyuchili phones gave everything works at the phone number say 103. beginning to call him after hearing the caller, but he does not. All are connected via fax Linksys RTP300 ikscherue 1270. Help customize the work worth it.
    Translation:
    Poklyuchili telefones deu tudo funciona pelo número de telefone dizer 103. Começam a chamá-lo após ouvir o chamador, mas ele não. Todos estão conectados via fax Linksys RTP300 ikscherue 1270. Ajuda para personalizar o trabalho valeu a pena.
    http://translate.google.com/translate_t?langpair=ru|en
    Andy
  4. mnemonix
    Jan 8, 2008
    13
    Help with fax us hear, but we have not. that must include a router
