Solved Notifications
Discussion in 'iOS' started by Braden Smith, Jan 13, 2017.
  1. Braden Smith
    Jan 13, 2017
    Is anyone else experiencing a bug with notifications on IOS? It seems like an update in early December/November must have broken it. Even when notifications are turned off for the application...the 3CX app still rings whenever there is a call. Not ideal, we ended up uninstalling it.
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,476
    67
  3. Braden Smith
    Jan 13, 2017
    So basically we have to disconnect account when we don't want our cell phone ringing? Because we may not want to set it to DND because we are at our desk.
  4. Vali_3CX
    Dec 12, 2008
    1,476
    67
    Apple philosophy says when you, as user, put an application in the background, it means you're no longer interested in it.
    Therefore, in your case, when you exit or put the 3cx client in the background, it not only means you're no longer interested in it, but also you even don't want to receive calls - so, in this case, what does matter if you have, or not, a configured account?
  5. Braden Smith
    Jan 13, 2017
    But that's the problem...even when the app is closed and completely shut down...it still rings...
  6. Vali_3CX
    Dec 12, 2008
    1,476
    67
