NOTIFY and Method Not Allowed
Discussion in '3CX Phone System - General' started by lamsoft, Feb 10, 2009.
  1. lamsoft
    Jan 23, 2009
    12
    Hi, all.
    I have a VOIP Gateway (Linksys SPA-3102) on my network, after I configured other clients can successfully call out or in.
    But my VOIP Gateway consistently send a command and the server keep replies method not allowed, what does it mean?
    Code:
    NOTIFY sip:192.168.0.1 SIP/2.0
    Via: SIP/2.0/UDP 192.168.0.250:5060;branch=z9hG4bK-7c9fc838;rport=5060
    Max-Forwards: 70
    To: <sip:192.168.0.1>
    From: SPA-3102 <sip:1314@192.168.0.1>;tag=25fe529612d612cao0
    Call-ID: c04262c6-70dc05a@192.168.0.250
    CSeq: 45316 NOTIFY
    User-Agent: Linksys/SPA3102-5.1.7(GW)
    Event: keep-alive
    Content-Length: 0
    15:38:40.155|.\DialogUsageManager.cxx(1299)|Trace5|Resip|::ResipLogger:Got: SipReq:  NOTIFY 192.168.0.1 tid=-7c9fc838 cseq=NOTIFY / 45316 from(wire)
    15:38:40.155|.\DialogUsageManager.cxx(1617)|Debug8|Resip|::ResipLogger:DialogUsageManager::processRequest: SipReq:  NOTIFY 192.168.0.1 tid=-7c9fc838 cseq=NOTIFY / 45316 from(wire)
    15:38:40.155|.\DialogSetId.cxx(34)|Debug8|Resip|::ResipLogger:********** Generated Local Tag ***********
    15:38:40.155|.\DialogSet.cxx(84)|Debug8|Resip|::ResipLogger: ************* Created DialogSet(UAS)  -- c04262c6-70dc05a@192.168.0.250-9562985a*************
    15:38:40.155|.\DialogId.cxx(50)|Debug8|Resip|::ResipLogger:DialogId::DialogId: c04262c6-70dc05a@192.168.0.250-c66f4e00-25fe529612d612cao0
    15:38:40.155|.\DialogId.cxx(50)|Debug8|Resip|::ResipLogger:DialogId::DialogId: c04262c6-70dc05a@192.168.0.250-ae76634a-25fe529612d612cao0
    15:38:40.155|.\ServerOutOfDialogReq.cxx(67)|Debug8|Resip|::ResipLogger:ServerOutOfDialogReq::dispatch - handler not found for NOTIFY method - sending 405.
    15:38:40.155|.\Helper.cxx(372)|Debug8|Resip|::ResipLogger:Helper::makeResponse(SipReq:  NOTIFY 192.168.0.1 tid=-7c9fc838 cseq=NOTIFY / 45316 from(wire) code=405 reason=
    15:38:40.155|.\DialogUsageManager.cxx(832)|Debug8|Resip|::ResipLogger:SEND:
    SIP/2.0 405 Method Not Allowed
    To: <sip:192.168.0.1>;tag=0a73d257
    From: "SPA-3102"<sip:1314@192.168.0.1>;tag=25fe529612d612cao0
    CSeq: 45316 NOTIFY
    User-Agent: 3CXPhoneSystem 7.0.4708.0
    Content-Length: 0
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    The Linksys is sending a keep-alive to the PABX.
    This is not normally required and you can turn off the feature in the Linksys.
  3. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    William is correct: it's a keep-alive being sent from the phone to the proxy.
    A little clarification here: It can be safely be turned off in a LAN environment, but if the phone is connecting to the PBX from outside the PBX's LAN, it may assist the NAT device between the phone and the internet to keep the dynamic port mapping on the NAT device for SIP open, ensuring that the phone continues to receive to send and receive calls correctly. This will depend somewhat on the NAT implementation on the device.
    Regards
    Kevin
  4. lamsoft
    Jan 23, 2009
    12
    Then I disable the NAT keep alive setting.
    Thank you very much.
