Number Blacklist on V8
Discussion in '3CX Phone System - General' started by leejor, Oct 23, 2009.
  1. leejor
    11,277
    360
    A "number blacklist" has been mentioned as a new feature in Version 8 but after a test installation and a quick scan of the menus I'm unable to find where this is implemented. The manual doesn't seem to mention it either.
  2. ice
    ice New Member
    Jun 11, 2008
    108
    Extensions- Ext. number - BlackList tab
  3. leejor
    11,277
    360
    Sorry, I was assuming (incorrectly) that it was a blacklist for the entire system, not an extension by extension basis.
