Number Blacklist V15 Limit / Where is it stored
Discussion in '3CX Phone System - General' started by GEOIT, Mar 17, 2017.
  1. GEOIT
    Jan 26, 2017
    Does anyone know if there is also a limit (like V14) in number blacklists ?
    If not, can it handle about 4000 numbers ?
    And how it is possible to manage that list more comfortable (on GUI you can only delete one by on ) ?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,344
    535
    Hello @GEOIT
    Just added 4000 numbers in my v15 using a .svc and all numbers are imported successfully. Note that to delete them you have to do it manually.
  3. GEOIT
    Jan 26, 2017
    Yes adding is no problem, but can 3CX handle the amount of numbers on incoming call to check if allow or denied.
    And if not, how can i remove all numbers not only one by one (4000) ?
    The goal is, to update the number blacklist monthly with a script. Is it possible ?
  4. GiannosC_3CX
    GiannosC_3CX Guest
    Hi GEOIT,
    I am afraid this cannot currently be achieved but you can post this as a feature request in our ideas section of this forum so that other users can upvote your idea.
