Number blocking on extension basis
Discussion in 'Ideas' started by 3cxsbx, Jul 14, 2016.
  1. 3cxsbx
    Nov 18, 2015
    28
    Number blocking is great - only that it applies to all extensions. It would be great to have number blocking per extension or inbound rule.
    e.g. anonymous -> block for fax extension, but not for voice extension, etc.
