Number Format Problem
Discussion in '3CX Phone System - General' started by narkumas, Nov 8, 2017.
  1. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    25
    Hey!
    how can I handle numbers like this:
    +49(0)401234567
    The "0" is obsolete because of the country code. But many numbers have the format on webpages.
    Whe using the softclient I can reformat the number in outgoing rules, but my Fanvil phones are not able to handle those numbers.
    Any suggestions welcome.
  2. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    25
    Log:
    11/08/2017 1:29:33 PM - Call to T:Line:10008>>004901234567@[Dev:sip:999999999@sipconnect.qsc.de:5060] from L:9823.1[Extn:153] failed, cause: Cause: 503 490 not accepted/INVITE from x.x.x.x:5060
  3. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,049
    156
    Have you tried creating an outbound rule
    Calls to number starting with prefix = 00490
    Route settings - strip 5 digits , prepend 0049
  4. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    25
    Yes, I did. And it worked with my 3CX Softphone, but not with a Fanvil Deskphone
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,486
    358
    That means the phones send the number is a different format, run a wireshark capture and check how the number is being sent from the IP phone to the PBX so you can construct your outbound rule accordingly
