Number generation
Discussion in '3CX Phone System - General' started by Elvin Mammadov, Mar 13, 2017.
  1. Elvin Mammadov
    Feb 3, 2017
    42
    We have a request about number generation like DID numbers. The situation is like this:
    We have ordered a prefix from Ministry of Communications and Information Technology. For example: my number is; +1 312 810 4660. We have ordered a prefix such as 810 and we want to generate the rest of numbers in 3CX. It is about 9999 numbers. Is it possible to generate these numbers in 3CX, if yes how to do it?
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Elvin,
    What version of 3CX Phone system are you using?
  3. Elvin Mammadov
    Feb 3, 2017
    42
    We are using 3CX V15.
  4. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Elvin,
    May I refer you on this link https://www.3cx.com/blog/docs/importing-dids/
    This link explain you how to create your DID Inbound Rules in minutes in a .csv file and import it into 3CX Phone System.
    I hope the above is useful to you.
