Number of Calls in Use -> Active Calls
Discussion in '3CX Phone System - General' started by AndyBarr, Dec 6, 2016.
  1. AndyBarr
    Apr 8, 2015
    33
    Hi All,
    We seem to have an issue where there is no information show on the active calls screen.
    On the Dashboard it states:
    Number of calls in use 6/32
    But, when I click on this line it takes me to the Active Calls screen, it shows no information on these 6 calls or updates if I make a call while looking at this screen.
    Is this a known bug or do I need to do something to enable the Active Call information.
    Andy
  2. flextelecom
    Feb 2, 2016
    8
    Hi Andy,
    This should just work, all active calls should be visible.
    What version are you using?
    Also if you use the queue manager on the CTI/Softphone can you see the calls there?
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,326
    532
    Also try from an incognito tab in a supported browser. Some times you need to clear your cache.
  4. pedroben
    Aug 2, 2016
    10
    Hi, can confirm the same issue. Currently on version 15.0.57336.0
  5. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Yes I've had this happen to me a few times as well ... next time I'll try an incognito tab.
  6. YiannisH_3CX
    May 10, 2016
    7,326
    532
    @pedroben
    Please upgrade to the current service pack as there are many bug fixes included and see if that resolves your issue.
    @JasonNadeau
    What Service pack are you running? Did you have this issue recently?
  7. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    @YiannisH_3CX , This was one or two service packs ago. I've only had this issue at 2 customer sites, and both those sites supplied and setup the server so I can't say it's a 3CX issue for certain ...
