Number transformation
Discussion in '3CX Phone System - General' started by Borsoock, Apr 16, 2007.
  1. Borsoock
    Borsoock New Member
    Apr 8, 2007
    149
    Hello
    I'm using Nokia E65 SIP client with 3CX. I try to set up number transfromation rule to be able to dial local calls directly from cellphone phonebook.
    My 3CX is connected to office Avaya PBX via SPA3102.
    I store numbers in Nokia in 'GSM format': +XX YYYYYYYYY where XX is country code.
    To be able to make local calls by 3CX and analog line I must remove first 3 characters (+XX) and add 0 (Avaya PBX outside line). So, in 3CX outbond rules I defined following:
    For numberd starting with '+' use transformation mask 'rrr0'.
    Unfortunately it doesn't work:
    17:28:58.093 CallConf::eek:nIncoming Can not resolve target for call from <sip:103@87.204.241.26>;tag=uiud52eitphc60gt7c5u to <sip:+48888218882@87.204.241.26;user=phone>
    17:28:58.093 CallConf::Rejected Call (C:6) is rejected: Target is not resolved
    17:28:58.078 CallConf::eek:nIncoming Incoming call from Ext.103 to sip:+48888218882@87.204.241.26
    Correct me if I'm wrong, but I think system doesn't use defined transformation mask because starting '+' is not a number. Is that any way to solve this problem? I'd like to avoid duplicating numbers in handy's phonebook in '3CX compatible' format.
    Marcin
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,935
    250
    We will test this and let you know. This mask should work... If not we will fix it...
  3. Borsoock
    Borsoock New Member
    Apr 8, 2007
    149
    Many thanks Nick. This is why I really like 3CX - excellent communication with users community!
  4. kevin
    kevin Member
    Nov 23, 2006
    316
    We have implemented a fix for this and it should be available in the next version. Thanks for pointing this out.
  5. Borsoock
    Borsoock New Member
    Apr 8, 2007
    149
    Thanks Kevin!
    Now I really can't wait new version :).
