Number Translation
Discussion in 'Ideas' started by Chris Coleman, Apr 1, 2017.
Number Translation 5 5 1votes
5/5, 1 vote
  1. Chris Coleman
    Mar 24, 2017
    Would it be possible to add number translation to the system so that if somebody dials the DDI number of another extension rather than the extension number it is automatically converted rather than sending the call out of a trunk and back in again?
    For example; extension 1000 has the DDI 01234 567890. If another extension dials 01234 567890 could the system translate this number to 1000 and route the call internally?
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    I think putting in the users DDI as the sip alias of the extension will do what you want ...
  3. leejor
    10,758
    286
  4. Chris Coleman
    Mar 24, 2017
    Yes, Exactly like that. Thanks for pointing it out....
