Numbers pressed during a call sent wrong
Discussion in '3CX Phone System - General' started by henington, Aug 12, 2010.
  1. henington
    Aug 12, 2010
    14
    I'm using 3cx with Skype Gate and have everything working well. Inbound ( calls to my skype ID ) and outbound to regular numbers via the gateway. There are a couple issues.
    #1 when i make test calls to my cell or wifes cell, i can answer the phone and there is about a 3 sec delay before the call appears to be fully "connected" So the call usually starts when i'm on my 2nd to 3rd "Hello?"
    #2 When I call an external conference line, the call is connected and the external line says "Please enter your conference ID" From my softphone I dial 123456789, and press #. The response I get is "The code you entered, 111223456789 is invalid." So the problem is the numbers I am pressing, 1 for example is getting sent through as 111.
    Any ideas why the numbers are getting sent funky ? Or why the delay in the calls? I think if i go to Skype SIP Beta i can not use the gateway at all, will that resolve these issues?
    Everything works PERFECT from skype native.
