object duplication error
Discussion in '3CX Phone System - General' started by piloteight, Oct 3, 2009.
  1. piloteight
    Oct 4, 2008
    6
    3cx version Installed Version: 6.1.0 - free version
    i have created 7 extensions and 6 DIDs when I try to add another DID i got this error. How to fix?
    outbound calls to the world and internal calls have no problem.
    any help is appreciated.
    Jay
    Object duplication error
    Cannot save Inbound DID rule object: ERROR: duplicate key violates unique constraint "inboundruledid_pkey"<br>#0 C:\Program Files\3CX PhoneSystem\Data\Http\functions\fInboundRuleDID.php(121): safeExec(Object(PDOStatement), 'Cannot save Inb...')<br />
    #1 C:\Program Files\3CX PhoneSystem\Data\Http\did_configuration.php(117): fInboundRuleDID::save(Object(oInboundRuleDID))<br />
    #2 {main}
  2. piloteight
    Oct 4, 2008
    6
    I am still trying to figure this out. if anyone has any idea. i would like to heard it.
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,406
    81
    Maybe you could try and install Version 8 Instead of the "old" 6 Version.
    I dont think it would be too much of a hassle to spend 5 minutes doing so, you can get it from here: http://www.3cx.com/downloads/3CXPhoneSystem8.exe
    It will most surely fix your problems.
  4. piloteight
    Oct 4, 2008
    6
    I can give this a try. CAn you do an in place upgrade from 6 to 8 ?
    Jay
