Object Duplication Error
Discussion in '3CX Phone System - General' started by scottyork, Dec 6, 2007.
  1. scottyork
    Jun 1, 2007
    64
    Getting this errror
    Cannot save Gateway object: ERROR: duplicate key violates unique constraint "gateway_pkey"<br>#0 C:\Program Files\3CX PhoneSystem\Data\Http\functions\fGateway.php(247): safeExec(Object(PDOStatement), 'Cannot save Gat...')<br />
    #1 C:\Program Files\3CX PhoneSystem\Data\Http\gateway_lines_upd.php(689): fGateway::save(Object(oGateway))<br />
    #2 {main}
    When trying to add new gateway. Have just upgraded from 3.1 to "final" v.5
    Can't seem to add new DIDs either with similar error
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    I hit this to. Just backup then restore the system file again.
    It should be solved this issue.
    This error only affect the CDR (call log). The call function should be works fine.
  3. scottyork
    Jun 1, 2007
    64
    Your fix works perfectly
    :D
    Many thanks!
