- Joined
- Nov 7, 2008
- Messages
- 7
- Reaction score
- 0
Every few calls or so I experience no audio on the incoming side. This error is generated:
I'm guessing that there is a codec issue? I'm using a PAP2 and have limited 3CX and the PAP2 to use G711u ONLY. I've been trying to track down the source of choppy outgoing audio as well. All of the required ports have been forwarded at my router and 3CX passes the firewall test.
3CX is installed on Windows Server 2003 sbs. Do I need to configure any settings within Windows 2003? Windows firewall is disabled due to the use of RAS.
Code:
[MS003005] C:40.2: Failed to create Endpoint: (destination=192.168.1.100)
EndPoint: ID=00000050@(LOCAL)
LOGID=C:40.2 Status: MSEP_FAILED
RTP:192.168.1.104:7084
RTCP:192.168.1.104:7085
STUN RTP:0.0.0.0:0
STUN RTCP:0.0.0.0:0
Coder:
NOT SET
101:telephony-event
Party ptime:20
Party RTP:0.0.0.0:0
Party RTCP:0.0.0.0:0
Decoders:
[empty]
