ODBC Directory sync
Discussion in 'Ideas' started by expertit, Dec 14, 2015.
  1. expertit
    Jan 4, 2010
    At the moment, once an entry is in the Company Phonebook (from ODBC) you can’t remove an individual item. Will you add this functionality in due course otherwise we would have to trash ALL sync’d entries, which would be a real pain.
  2. richardwvm
    Dec 21, 2015
    27
    Yes and I can't see why editing shouldn't be possible also.
