ODBC MSSQL Connection String Can't Contain = Equal Sign V15 SP1
Discussion in '3CX Phone System - General' started by JStellato, Sep 12, 2016.
  1. JStellato
    Dec 17, 2015
    33
    6
    We are trying to get the ODBC connection string working, in the tool it works properly, but according to the documentation here:
    http://www.3cx.com/docs/odbc-search-pho ... zbi4eu87wv
    In case of MSSQL database you will have to specify a connection string including user and password of the database. To do so, in the DSN Name field should be appended: “ODBCdatabase;uid=USER;pwd=PASS;”
    The problem is in V15 SP1, if you copy that statement verbatim and click ok, then click back on ODBC you can see it cuts off the odbc DSN connection string at the first equals = sign.
    Is there a way around this?
      File size:
      16.2 KB
      472
  2. enrico.razzoli
    Oct 9, 2016
    I have exactly the same problem !!
    Any fix done ???
  3. XanthiZ
    3CX Support
    Dec 18, 2015
    46
    7
    Hello JStellato ,
    In V15 SP2 this issue is already fixed !
    Soon we are going to release the V15 SP2 , so please be patient!
