Odd firewall intercept
Discussion in '3CX Phone System - General' started by haywardi, Jan 18, 2016.
  1. haywardi
    Feb 27, 2011
    84
    Has anyone come across the following..
    I've started monitoring my firewall much more recently and have noticed that I'm getting a "blocked" entry.
    This wouldn't normally worry me except the blocked IP address is MY OWN external IP address trying to access port 5000.... Seems to be initiated from port 34572..
    Is this normal behaviour of 3CX, or is it someone trying to spoof my own IP address?
    Thoughts/comments welcome.
    Iain
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    Unknown as not enough info.
    You might try to do a wireshark capture and see if any additional details can be had that would help identify the source. I assume it could be someone trying to get access, but you did not indicate the ports your system is set to use. If running Abyss and a later version of 3CX, then port 5000/5001 (HTTP/HTTPS) is used to gain access to the log in page.
  3. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,386
    88
    It could be either, but if you have something internally on your network trying to connect to your Public IP from inside your network then I believe this can happen.
    The most common reason for this happening is when you have Split DNS setup, but some of the endpoints does not resolve to your Local IP so it tries to go to the Public IP.
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    Someone may have static DNS entries of a public DNS server. I had someone not able to access email when they were in the office. Once I changed DNS to DHCP they were up and running.
    This would have been a similar scenario as you.
